What is DGN File??? How to Open it???
Good Day Guys,
Anyone knows DGN Files??? Our company received DGN Files but I cant open it.
Thanks in advance for your ideas,,,
A DGN file is the Microstation equivalent of An AutoCAD DWG file. AutoCAD 2014 can open DGN files but I think AutoCAD 2010 can do it too. Try the AutoCAD command DGNIMPORT to test it.
I find the import process generally doesn't work too well though.
lIke Organic try and stay away from dgn,s 1thing to do after import is to purge orphaned line types unfortunately it's in 2015+ the 2013 fix I downloaded from Autodesk did not work..
One thing to look at is a translation table which helps to do a better job of importing.
Very useful answers guys...I open the files now..
Thanks so much,,,another knowledge
