Autocad LT - Dynamic block Rotate and Stretch
Hello,
I'm trying to create a dynamic block of a partition's angle. My problem is: when I rotate the two lines, the jonction point breaks out and instead of having a clean shoulder, I have two separate lines. I would ideally need to rotate and stretch. If anyone could help that would be great
Hello,
Can you post a screenshot of the various configurations you would like the geometry to look?
If you have got a start on this, post the DWG also.
Hello,
Thanks for your quick reply. Indeed, I'm trying to build a partition block with an angle that would rotate. TestAngle Model.jpg
Many Thanks
Paul
