I am trying to change the splash screen of autocad 2012 by editing AcBrandRes.dll in resource hacker application. But when I try to replace the bitmap with another one, I get operation failed error. I tried again with matching the resolution and dpi of the image too but failed. I am running windows 8.1 (64bit)
What should I do?
Find something more valuable to do with your time?:lol:
I understand we all want to see our name in lights but you would be doing yourself a bigger favor by just eliminating it. Shave a couple of seconds off the start up time.
Edited by ReMark
From some brief research on this, AutoCAD 2011 (and I believe AutoCAD 2012) should edit the C:\Program Files\Autodesk\AutoCAD 2011\acadres.dll. AcBrandRes.dll does not exist in AutoCAD 2011.
If I find the time today, I'll check which file(s) need edited.
AutoCAD 2011, you need to go to C:\Program Files\Autodesk\AutoCAD 2011\acadres.dll, open acadres.dll with Resource Hacker and expand the BITMAP folder, scroll down to 144:1033 Go to menu bar Action (or Right-Click) and select Replace Bitmap, select Open File With New Bitmap, browse to your custom .bmp then Save Resource Hacker made a file called acadres_original.dll automagically, but I made a backup as well. That will replace default splash .bmp with your custom .bmp. Took me 10 seconds.
