Is there a way to isolate Block base on the Block name?
Scenario: ext'g drawings contains many blocks. Most blocks is under some layer names other then layer 0, some are by design, some are just mistakes
Question: Is there a way to isolate those blocks base on their block layer?
Example:
Layer 1 has Block A which contains layer 10, 11 & 12
Layer 2 has Block B which contains layer 20, 21 & 22
Layer 3 has Block C which contains layer 30, 31 & 32
How to isolate Layer 2 such that Block B which contains layer 20, 21 & 22 will be isolated as well?
Reason: I need to delete a particular layer but i do not know if it assign to a Block, since isolating that layer, will not yield anything on the screen. If i use LAYDEL, any blocks under that layer will get without me knowing it
I cannot change all blocks to layer 0 since it is not my drawing.
Edited by Tripledot
This is pretty rough but a starting point
(setq  doc (vla-get-activedocument (vlax-get-acad-object))) ; open database
(setq allblocks (vla-get-blocks doc))
(vlax-for block allblocks
(setq blkname (vla-get-name block))
(if  (not (wcmatch (strcase blkname t) "*_space*"))
(vlax-for* *ent block
(setq layname (vla-get-layer ent))
  (if (= layname "12")(alert (strcat blkname " Block has layer 12 " )))
  ) ;_ end of vlax-for
  ) ;_ end of if
  ) ;_ end of if
thanks. not familair with lsp other then applying it to dwg. :oops:
to make clear, its concerning the layer of the block rather then name of the block.
I come across a lisp by Lee McDonnell.
It does inform through a message that there are *how many* blocks in that particular layer. Unfortunately, it does not indicate which block it is. And there is no way of knowing when dealing with hundreds of blocks/nested blocks
; Get All on Layer by Lee McDonnell
; Args:-  layer (string)
(defun get_all_on_layer (layer / ss eLst blks att aBlst ents eBlst)
 (if (tblsearch "LAYER" layer)
     (setq eBlst (strcat "Entities within Blocks on Layer " layer ": \n\n"))
     (foreach x (blk_list)
   (setq ents (entnext (tblobjname "BLOCK" x)))
   (while ents
     (if (eq layer (cdr (assoc 8 (entget ents))))
       (setq eBlst (strcat eBlst (cdr (assoc 0 (entget ents))) " Within Block: " x "\n")))
     (setq ents (entnext ents))))
     (alert eBlst))
   (princ "\n<!> Layer Not Found in Drawing <!>"))
 (princ))
(defun blk_list (/ bLst)
 (vlax-for blk
       (vla-get-blocks
   (setq bLst (cons (vla-get-name blk) bLst)))
 (setq bLst (vl-remove-if
          (function
        (lambda (x) (or (wcmatch x "*PAPER*") (wcmatch x "*MODEL*")))) bLst))
 bLst)
(defun c:GL ()
 (get_all_on_layer (getstring "\nSpecify Layer: "))
 (princ))
Version 2 give it a
  (vlax-for ent block
  (cond  ((= layname "10")(vla-put-layer ent "new layer"))
         ((= layname "12")(vla-put-layer ent "new layer"))
; repeat as required
  ) ;_ end of if
QSelect or filter will get you there. You can filter out blocks and then filter by layer. This will get you a selection set of all the blocks on that layer. You can run list to find out the block names and how many of each.
am i to put in the layer name highlighted in red?
Example: Out of 100 over layering names, I need to isolate layer name "DISCREPANCIES"
I did that but nothing happen. :(
Version 2 give it a
  (vlax-for ent block
  (cond  ((= layname "[b][color=red]DISCREPANCIES[/color][/b]")(vla-put-layer ent "[color=red][b]DISCREPANCIES[/b][/color]"))
         ((= layname "[color=red][b]DISCREPANCIES[/b][/color]")(vla-put-layer ent "[color=red][b]DISCREPANCIES[/b][/color]"))
  ) ;_ end of if
