Bogbadbob658 Posted February 26, 2016 Posted February 26, 2016 I’m having a problem flattening items in a drawing. I have been sent a file which has items with numerous z values. I moved them from 0,0,0 to 0,0,1e99 and then back again from 0,0,0 to -1e99 but they now have a random Z value? I’m confused, I thought this would set all the Z values to 0. Quote
ReMark Posted February 26, 2016 Posted February 26, 2016 Can you attach a sample drawing with some of these recalcitrant objects in it so we can see/test for ourselves? Quote
RobDraw Posted February 26, 2016 Posted February 26, 2016 All you did was move them back to the same position. If there were z values when you started, then they will be the same afterwards. Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 Test file attached. I managed to strip out all but 3 lines. The middle line has z values set to 0 other 2 are not. test.dwg Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 All you did was move them back to the same position. If there were z values when you started, then they will be the same afterwards. As I understand it, by moving everything using this method everything should come back to a Z value of '0'. Quote
ReMark Posted February 26, 2016 Posted February 26, 2016 Test file attached. I managed to strip out all but 3 lines. The middle line has z values set to 0 other 2 are not. That was too easy. OK...give me the real test drawing. Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 Ok. How did you do it? Every time I do it, it keeps bringing them back to -31.475. Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 If I move the 3 lines to from 0,0,0 to 0,0,1e99 and then move them back form 0,0,0 to 0,0,-1e99 all three lines up with the same Z value of -31.475 Quote
ReMark Posted February 26, 2016 Posted February 26, 2016 OK. I thought maybe the lines were returning to their original elevations after you saved and reopened the drawing. My secret weapon was...........the CHANGE command > Properties and the Elevation option. Old school to be sure but sometimes old stuff works. Which is what my wife has been known to say to me sometimes. LoL Quote
RobDraw Posted February 26, 2016 Posted February 26, 2016 I told you this before. What you are doing does not flatten anything. In the case of a few lines or even hundreds of them, it is easy enough to select them and change the z values in the properties box. You could also use the flatten command. Quote
RobDraw Posted February 26, 2016 Posted February 26, 2016 Ya know, that might have worked on older versions because of precision limitations in AutoCAD. It looks they've gone beyond 1e99. Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 I told you this before. What you are doing does not flatten anything. In the case of a few lines or even hundreds of them, it is easy enough to select them and change the z values in the properties box. You could also use the flatten command. The file I'm working on has over 20,000 objects and beside flatten is not working on the polylines. When I draw a polyline or investigate an existing one. The elevation is set to 31.475 and the Z values of the individual points is '0'. No matter what I do I can't get ride of the level difference between the elevation and the Z value. I've tried flatten, change and elevation. when I move a using the 1e99 method everything gets set to a Z value of -31.475 which is obviously tied in to the polylines having a elevation of 31.475. even If I only move a single line with both Z values set to '0', using the 1e99 method, it goes to -31.475. I just don't get it! Quote
ReMark Posted February 26, 2016 Posted February 26, 2016 If I were you I'd stop trying to get the macro to work. OK I'm confused. You want all objects to have a Z of 0 yet you are drawing polylines with elevation set to 31.475? I don't suppose we could get our hands on the full drawing (via Dropbox for instance)? Quote
Bogbadbob658 Posted February 26, 2016 Author Posted February 26, 2016 OK. I've finally figured it out. It's because I had changed the UCS. I used an object to change my UCS which had a Z value of 31.452, therefore my working plane (not sure that's the correct term) was set to 31.452 so whenever I used flatten, change or 1e99 it moved it to 31.452 or -31.452 . Once I changed it back to 'World' everything worked as normal. Is there a way you can check what elevation your working plane is set to? Thank you all for all your help. Quote
BKT Posted February 26, 2016 Posted February 26, 2016 You can check the elevation by entering it at the command line: ELEVATION Quote
eldon Posted February 27, 2016 Posted February 27, 2016 If you have set up a UCS that is not at zero elevation, then enter the command "Base". Since the base point is usually at 0,0,0 unless it has been re-set, then the current elevation relative to the World UCS is shown. Also, if you had the UCS icon showing, then that would show whether you were in World UCS or something else. In the drawing posted, there were some entities at a good distance from 0,0, almost as if the Move command had been wrongly applied. A useful command is STATUS which shows the extent of entities in the drawing. The test drawing shows some alarmingly large numbers for the coordinates. Quote
