I wondering how to read physical address with AutoLISP.
Regards,
MMS
Regards,
MMS
I wonder if you could clarify further what you mean by physical address?
Ethernet adapter / mac address.
Ahh, of course, excuse my ignorance :P
On first thoughts - I would doubt it. But you can find out all sorts of things with the LISP, like version, time, date, etc etc - so I wouldn't rule it out completely. :)
For first network adapter:
(vl-registry-read "HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Class\\{4D36E972-E325-11CE-BFC1-08002bE10318}\\0001" "HardwareAddress")
Hey ASMI,
the result is nil.
Do you have any code ?
Thanks
MMS
What operating system you use? What is connection type: onboard LAN-adapter, separate LAN-adapter or WiFi?
http://www.caduser.ru/cgi-bin/f1/board.cgi?t=43327xi&page=1 :
(defun vk_getmacaddress (/             locatorobj    serviceobj
                            securityobj   objectsetobj  outlist
 (setq locatorobj (vlax-create-object "WbemScripting.SWbemLocator"))
 (setq serviceobj
        (vlax-invoke
          locatorobj 'connectserver nil nil nil nil nil nil nil nil) ;_ end of vlax-invoke
       ) ;_ end of setq
 (setq objectsetobj
        (vlax-invoke
          serviceobj
          'execquery
          "Select * from Win32_NetworkAdapter"
       ) ;_ end of setq
 (vlax-for obj objectsetobj
   (if (wcmatch (vl-princ-to-string (vlax-get obj 'adaptertype))
                "Ethernet 802.*"
                ) ;_ end of wcmatch
     (setq outlist (cons (vlax-get obj 'macaddress) outlist))
     ) ;_ end of if
   ) ;_ end of vlax-for
 (foreach obj (list locatorobj serviceobj securityobj objectsetobj)
   (and obj (vlax-release-object obj))
   ) ;_ end of foreach
 outlist
 ) ;_ end of defun
I'm use LAN-adapter.
Thanks.
Hi. Your OS is Vista? There seems missed "HardwareAddress" key in the Registry :x Try to use kpblc function.
