Hi,
I'm trying to create a block and well i'm not sure why it doesn't work.
Could someone help me out or guide me.
(defun CreationBois (Nom Dim1 Dim2)
    (entmake (list '(0 . "BLOCK")
	           (cons 2 nom)
	           (cons 10 (list (/ Dim1 2) Dim2))
	           '(70 . 1)
    (entmake
	(list '(0 . "LINE")
	      '(8 . "-LU BOIS")
	      '(10 0 0)
	      (cons 11 (list Dim1 0))
    (entmake (list '(0 . "LINE")
	           '(8 . "-LU BOIS")
	           (cons 10 (list Dim1 0))
	           (cons 11 (list Dim1 Dim2))
	           '(8 . "-LU BOIS")
	            (cons 10 (list Dim1 Dim2))
	            (cons 11 (list 0 Dim2))
		   '(8 . "-LU BOIS")
		    (cons 10 (list 0 Dim1))
		   '(11 0 0)
		   '(8 . "-LU BOIS")
		   '(10 0 0)
		   '(8 . "-LU BOIS")
    (entmake (list '(0 . "ENDBLK")
		   '(8 . "_LU BOIS")
it used to work! but not exactly like this.
and i receive no error.
Regards !
Are you specifically trying to make an anonymous block?
If so, what block name are you passing to the function?
This works for me: (CreationBois "*U1" 8 9 )
I'm trying to pass a block name of a 4x4.
It's not annonymous
Well I figured it out!!
had to put
(70 . 1) to (70 . 2)
Hi Frank,
Try this minimized codes :D
(defun CreationBois  (nom Dim1 Dim2)
 (if (tblsearch "BLOCK" nom)
   (princ
     (strcat "\nBlock name <" nom "> is already existed !"))
                    (cons 2 nom)
                    '(70 . 0)
     (mapcar '(lambda (x y)
                (entmake
                  (list '(0 . "LINE")
                        '(8 . "-LU BOIS")
                        x
                        y
             (list '(10 0 0)
                   '(10 0 0)
                   (cons 10 (list Dim1 0)))
             (list (cons 11 (list Dim1 0))
                   '(11 0 0)
                   (cons 11 (list 0 Dim2)))
                    '(8 . "-LU BOIS")
I was trying to minimize the code with a foreach :)
If I can't make it. ill try yours.
Thank !
Cheers and Beers !
It's not annonymous
If you pass bitcode 1 to group 70, then the block name must begin with [*] because it will be an anonymous block.
You should change the group 70 to 0, not 2 because 2 indicates that you are going to attach attributes to it.
Ok so i've come this far and I think theirs something I dont get with the list and quote.
	   '(100 . "AcDbEntity")
	   '(100 . "AcDbBlockBegin")
	   (cons 2 nom)
	   '(8 . "_LU BOIS")
	   '(70 . 0)
   (setq points  (list (list (list(0 0)) (list (Dim1 0)))
;;;		        '((list Dim1 0) (list Dim1 Dim2))
;;;		        '((list Dim1 Dim2) (list 0 Dim2))
;;;		        '((list 0 Dim1) (list 0 0))
;;;		        '((list Dim1 Dim2) (list 0 0))
;;;		        '((list Dim1 0) (list 0 Dim2))
   (foreach point points
(entmake
    (list '(0 . "LINE")
	  '(8 . "_LU BOIS")
	  (cons 10 (car points))
	  (cons 11 (cadr points))
	   '(100 . "AcDbBlockEnd")
	   '(8 . "_LU BOIS")
Now what ever I do it always gives me and error.
Any suggestions?
For starters :
change (car points) to (car point) and so on
There is no real need for the 100 groups as far as I know
"BLOCK" group 10 needs x y and z values
Hint:
(cons 1 (list 2 3 4)) == (1 2 3 4) == (list 1 2 3 4)
I would also suggest entmake'ing the BLOCK and ENDBLK entities on layer "0" to avoid the potential for unpurgeable layers.
(defun creationbois ( nom dim1 dim2 )
   (if (not (tblsearch "block" nom))
           (entmake (list '(0 . "BLOCK") '(8 . "0") (cons 2 nom) (list 10 (/ dim1 2.0) dim2) '(70 . 0)))
           (foreach x
               (list
                   (list '(10 0 0)            (list 11 dim1 0))
                   (list  (list 10 dim1 0)    (list 11 dim1 dim2))
                   (list  (list 10 dim1 dim2) (list 11 0 dim2))
                   (list  (list 10 0 dim2)   '(11 0 0))
                   (list '(10 0 0)            (list 11 dim1 dim2))
                   (list  (list 10 0 dim2)    (list 11 dim1 0))
               (entmake (list '(0 . "LINE") '(8 . "_LU BOIS") (car x) (cadr x)))
           (entmake '((0 . "ENDBLK") (8 . "0")))
Well thank everyone!
I should've though of putting the list inside the foreach :(
Anywho !
Works like a charm now :D was looking to make my code smaller also and more readable.
Cheers !
Someday ill be an expert like you guys!
You're welcome - but please note that the list is not 'inside' the foreach expression, it still constitutes the list argument for the foreach function (i.e. the 'points' variable in your earlier code).
I would take a slightly diffrent approach to your foreach making the lines if you have 3 lines or 4 or 5 or 20 you need to redo the code every time I would make the list external use Length to find out how many lines and use NTH function for 10&11 pts ((1 2)(3 4)(5 6)(7 8)........)
Yeah I might of expressed myself a little off here but it's exactly what I meant. Thanks Lee ! :)
Not sure what you mean! my list is always different. Do you have more of an exemple :D.
It's always good to see different ways of thinking .
Cheers!
If you look at Lees code you have hardcoded 6 lines You could pass any number of lines eg (((0 0)(1 1))((1 1)(11 5 5))((5 5)(22 6))) this would be 3 lines.
Ok I get what you mean. but this code will always use 6 lines. Since it creates the same type of blocks.
But if I would like to use it else where it would but a good idea to put it as you say.
Let say i'd like to do a rectangle or a 5 sized polygone.
Thanks for your insigh!
