All I need this function to do is to allow me to export a selection in model space to a new, different .dxf file (specifically, AutoCAD 2000/LT2000 DXF format). Doesn't matter where the coordinates end up.
And the function can let me name this new dxf file and file location.
Is such a function possible?
use filedia 0 and then dxfout
gr. Rlx
Oh, that function is exactly what I'm looking for, but do you think you can show me how I would make a script for dxfout so that dxf2000 is the default and it prompts me make an object selection? I think I'd rather have the dialog box for file path selection too, so I'm probably gonna keep filedia as 1.
EDIT:
Oh, and 1 last thing. Is there a way to add in the purge command to apply to the new dxf file?
Edited by KendiKong
EDIT:
Check this one from Lee :
http://www.cadtutor.net/forum/showthread.php?70489-Dxf-to-file-location/page2&highlight=dxfout
Gr. Rlx
btw ,
if you dxf out , no use for purge unless your template is allready 'contaminated'
But if you want to script something , here's something about scripts too :
http://www.cadtutor.net/forum/showthread.php?95560-Script.-Save-Open-Close-Switch-back-to-original-DWG&highlight=rlxscript
be aware , scripts dont work with dialogs (obviously)
