JAmbrose
Polyline global width keeps changing to varies?
JAmbrose
Hi all,
I am using AutoCad 2015, the problem I have is that when I select a polyline, do select similar and change the global width to 0.15 (for example) then when I save the drawing and re-open it, when I select the polyline and select similar, it says the global width is varies. I know this sounds like a rather minor problem but at work, everything gets checked and these kind of small errors do have a rather large effect on our performance rating. The strange thing about this is that it only happens for some drawings and not all drawings. :ouch: Unfortunately that is all the information I really have on the problem so I hope that is enough.
Thank you for your time,
Josh
Share this post
Link to post
SLW210
Can you post a .dwg that does this?
Share this post
Link to post
