Exporting command shortcuts from Acad2011 to Acad2016
Hi folks!
Well the title says it all.
I want to export all of my keyboard shortcuts from Autocad 2011 to version 2016 thats instaled on another computer.
How to do this?
Thank you.
You may want to check that you are using a custom menu or you have added code to files like acaddoc.lsp acad.mnl acad.lsp acad.pgp etc you can pull this code out and make new MNU which can be simply partial loaded, or loaded on startup. Search for all your *.mnu files and see if they have your custom commands. Just me all our customisation is seperate to any acad default files. Also check your support paths for custom toolbars and menus.
