Hello,
I'm having issues when trying to find the intersection between two lwpolylines using the following code :
(vl-load-com)
(defun c:intersect (/ curve1-ename curve2-ename curve1-obj curve2-obj c d)
(setq curve1-ename (car (entsel "\nSelect first curve")))
(setq curve2-ename (car (entsel "\nSelect second curve")))
(setq curve1-obj (vlax-ename->vla-object curve1-ename))
(setq curve2-obj (vlax-ename->vla-object curve2-ename))
 (setq c
        (vlax-variant-value
          (vlax-invoke-method
        curve1-obj
        "IntersectWith"
        curve2-obj
        acExtendnone
(setq d
   (vl-catch-all-apply
          'vlax-safearray->list
          (list c)
 (entmakex (list (cons 0 "POINT")
         (cons 8 "00-CONSTR7")
                 (cons 10 (list (car d) (cadr d)))
All my lwpolylines have an elevation of 0 so this is not the issue. In the attached file, you will see small polyline in a blue revision cloud that apparently do not intersect the white polyline on layer "AXE-REF-PK" (but they obviously do ; an error of the type : "ActiveX Server returned an error : invalid index" is generated). This polyline has 1900+ vertexes so maybe there is a limitation that comes with the size. I have drawn above the exact same situation but with a poyline with half the vertexes. This time, the program finds an intersection everytime. There sure are many things I don't get with the intersectwith method :?
Does someone has ever encounter a similar problem ?
Regards,
Jacques
Intersectwith Method Issue.dwg
The intersectwith method can be temperamental if the objects are far from the origin - try the following code instead:
(defun c:inters ( / lst ob1 ob2 vec )
   (if (and (setq ob1 (car (entsel "\nSelect 1st curve: ")))
            (setq ob2 (car (entsel "\nSelect 2nd curve: ")))
            (setq ob1 (vlax-ename->vla-object ob1))
            (setq ob2 (vlax-ename->vla-object ob2))
       (if (or (setq lst (group3 (vlax-invoke ob1 'intersectwith ob2 acextendnone)))
               (   (lambda ( vec / ob3 ob4 )
                       (vla-move (setq ob3 (vla-copy ob1)) (vlax-3D-point vec) (vlax-3D-point 0 0))
                       (vla-move (setq ob4 (vla-copy ob2)) (vlax-3D-point vec) (vlax-3D-point 0 0))
                       (setq lst (group3 (vlax-invoke ob3 'intersectwith ob4 acextendnone))
                             lst (mapcar '(lambda ( x ) (mapcar '+ x vec)) lst)
                       (vla-delete ob3)
                       (vla-delete ob4)
                       lst
                   (vlax-curve-getstartpoint ob1)
           (foreach pnt lst (entmake (list '(0 . "POINT") '(8 . "00-CONSTR7") (cons 10 pnt))))
           (princ "\nNo intersection detected.")
(defun group3 ( lst / rtn )
   (repeat (/ (length lst) 3)
       (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
             lst (cdddr lst)
   (reverse rtn)
(vl-load-com) (princ)
Also, I would advise against defining intersect as a custom command, as this is already a built-in AutoCAD command.
Thanks a lot Lee Mac ! Works like a charm. I will keep in mind that AutoCAD can have problems with typical geographical coordinates values.
As for the intersect built-in command, I was not trying to emulate it. I actually need to be able to find the intersection between two polylines inside a larger lisp programm and your method does the job perfectly. And I managed to set eyes on news commands like vla-move !
Thanks again and best regards,
Jacques
You're welcome! - I'm glad the function is now performing well.
I'm aware that you were not trying to emulate the built-in AutoCAD command, but you should refrain from using the names of built-in commands as AutoLISP custom commands.
Ah ok. I understand now the true meaning of your comment. I will not do it in the future ! Thanks again.
Jacques
