notredave Posted March 7, 2016 Posted March 7, 2016 All, Can someone help me mirror this "tee" drawing please? I need the "tee" to be mirrored to other side in same plane. Is there any lisp routines out there to help me? Any tricks to mirror in iso mode? I need to mirror other things also. Thank you, David TEE.dwg Quote
RobDraw Posted March 8, 2016 Posted March 8, 2016 I tried doing it manually just to see how long it would take. I should have been able to do it in a matter of a minute or three including getting my head around the part. I was going to copy the pieces matching the distances from center and make a few adjustments for new view. It was not as easy as it should have been because the original is not quite accurate. Quote
notredave Posted March 8, 2016 Author Posted March 8, 2016 RobDraw, I appreciate you taking the time to look at this. I was hoping for a lisp routine that would mirror isometric objects but I haven't found one yet. I will keep looking. Quote
RobDraw Posted March 8, 2016 Posted March 8, 2016 If it were drawn correctly, it would be very easy. I'm afraid that even a lisp wouldn't be able to interpolate through the errors in order to give you satisfactory results. Quote
RobDraw Posted March 8, 2016 Posted March 8, 2016 That looks like you mirrored it. The end result in the diagram is a rotation of 90 degrees around the vertical pipe. Quote
RobDraw Posted March 11, 2016 Posted March 11, 2016 The OP was able to get someone to manually do this for him over at The Swamp. Quote
