In AutoCAD when you hold Ctrl+Arrow Key, it "nudges" any selected object(s) in the direction of the arrow key selected. Each nudge is a predefined distance, I believe that is based on the zoom factor. Can this value be adjusted, and if so what's the system variable? Thanks in advance!
-TZ
From CADsoft Consulting...
Snap mode affects the distance and direction in which the objects are nudged.
  • Nudge objects with Snap mode turned off: Objects move two pixels at a time; movement is relative and orthogonal to the screen, regardless of the view direction or the UCS orientation. That means if you are zoomed in, it will move a shorter distance than if you were zoomed out. Not very accurate way to move objects, so I would recommend using the Snap turned ON method if this is important to you.
  • Nudge objects with Snap mode turned on: Objects are moved in increments specified by the current snap spacing; movement is orthogonal to the X and Y axes of the current UCS and relative to the view direction.
Personally, I would not recommend the use of the NUDGE command in a precision drawing.
