A couple of things going on here. I have a "parent" lisp file that loads all of our other lisp routines. The parent file sets a .ini file as follows:
(setq ProTOOLS_PATH "\\\\rtfile\\technical\\Standards-RT\\ProductionTools\\"
GL:SYSINI (strcat ProTOOLS_PATH "System\\System.lpl"))
And later references it as:
(setq gl:SYSOP (dos_getini "Admin" nil gl:sysini))
or:
(defun f:path (x)(dos_getini "LOCATIONS" x GL:SYSINI)
I did not write these routines, as they were already assembled before I started working at this company. My problem is that we are switching servers FROM den-file TO rtfile. As you can see above, I have already changed the references to rtfile, however, the system.lpl file is still pulling or directing our lisp routines (dialogue boxes, symbol managers, etc.) to den-file. I have never heard of a .lpl file and the internet does not provide much help. How do I edit/redirect/open/etc. that .lpl file to reference the new rtfile?
I can attach the .lpl file if that would be beneficial???
Thank you everyone in advance!
Ryan
Anything? Mr. Leemac? Anyone have any ideas how to edit that file, or how to re-write the lisp to NOT reference that file?
Your protoolspath does not have a drive letter or is your server named rtfile ? ie \\rtfile\
Have you tried opening the file in a plain text editor, such as Windows Notepad?
  • 5 weeks later...
Sorry for such a late reply! I did not get a notification for any responses. Should have checked back in sooner!
Bigal - The drive is named rtfile.
Lee Mac - I don't know WHY I never thought of this, guess I thought this would be too easy?? but yes, this was it! Opened the file in Notepad and Bingo! Thanks for the help guys!
