miroslav_s Posted March 12, 2016 Posted March 12, 2016 Hi, I have been working with this ACA project (my house) in my spare time and came across one little problem today. When I wanted to place window tags I noticed that not all of my windows are shown in plane view. I realize why, because of the cut plane http://prntscr.com/aeh67n , when I change cut plane the window is visible. Is my only solution to change the setting for cut plane? Can I make same changes only for this window that is not showing up because I would like to avoid making changes in cut plane? Thanks in advance for all the help. Best regards to you all. Quote
