Hody!
I have question about handling error in autolisp(or visual lisp)
I would like that error function to do different things.
The situation is something like this.
i wanna insert an block. In the beginning the lisp routine asks two points and then it inserts an block and a text as well.
If it asks two points it and it sets new sys variables. Right, at this moment if i hit escape it restores old sys variables. If this routine inserts an block it also sets new values for sys variables and if i hit escape at this moment esc the old sys variables will be restored. But i also would like it to delete this inserted block. Now i can't use this (entlast) command. if i hit esc before it has inserted an block it will delete some other object or block which is last object.
Does anybody has a error handling routine which will restore sys variables any time when i hit esc and will only delet an block and text if it is inserted and won't delete last created object?
Complicated huh:((
Thanks,
M
Would you be able to post the routine as it stands so that it could be modified?
