is there a way to get a LINE's start X, Start Y, End X, End Y, Start Z, End Z, Length, Angle. and put it on excel???
i want to put it on excel and i want to input datas corresponding to those coordinates.
what im doing is data extraction, but its kinda hard to look for a single line and when i find it, thats where i input my data.
in excel it looks like this:
start X Start Y End X End Y Start Z End Z Length Angle CU AU HoleID
the CU AU HoleID part is where i input
is there an easier way to do this?
Its actually easy as you can work out the centre point of the line you can use various ssget options to retrieve the line, ssget "F" or "WP" or "CP" you need a tiny pick box etc Using entsel would be easier but alludes me for a pick point.
i still dont know what to do,
how can i code it???
The following simple example will write the data you have described to a tab-delimited Excel spreadsheet:
(defun c:linex ( / des enx ept idx sel spt xls )
   (if
       (and
           (setq sel (ssget '((0 . "LINE"))))
           (setq xls (getfiled "Create Excel File" "" "xls" 1))
       (if (setq des (open xls "w"))
               (repeat (setq idx (sslength sel))
                   (setq enx (entget (ssname sel (setq idx (1- idx))))
                         spt (cdr (assoc 10 enx))
                         ept (cdr (assoc 11 enx))
                   (write-line
                       (strcat
                           (rtos (car   spt)) "\t"
                           (rtos (cadr  spt)) "\t"
                           (rtos (car   ept)) "\t"
                           (rtos (cadr  ept)) "\t"
                           (rtos (caddr spt)) "\t"
                           (rtos (caddr ept)) "\t"
                           (rtos (distance spt ept)) "\t"
                           (angtos  (angle spt ept))
                       des
               (close des)
           (princ "\nUnable to open file for writing.")
Lee the poster has posted twice, once as output the other as input, wants to be able to find a line from excel hence the other post about ssget "F". The simple way is to write a macro in excel and copy and paste a column etc stepping through data, need a bit of time or need to do a getexcel.lsp type function. Maybe time at home tonight.
