Assign combination keys of Toggle OSMODE & 3DOSMODE on/off. Is it Possible???
It's Awesome! Thank you.. Thank you.. Thank you.. Thank you so much.. Thank you all! Specially for @tombu & @Grr.. That's a greate code what I've ever seen ever.. (it's because I'm newbie here! ^_^")
I've been replaced that code to my lsp doc and try with another combination methode and think. Is it possible could be add with any command or options? such as I try to insert Autosnap of Ontrack & Polar functions but without any interfere to which one of where's the buttons have been pressed. Please, see bellow here:
(defun c:TGG (/ )
 (if (not *ans*) (setq *ans* "Osmode"))
 (initget "Osmode 3dosmode [color=red][b]lineWeight onTrack Polar[/b][/color]")
 (setq *ans* (cond ( (getkword (strcat "\nToggle
[Osmode/3dosmode/[color=red][b]lineWeight/onTrack/Polar[/b][/color]] <" *ans* ">: "))) ( *ans* )))
 (cond
  ((= *ans* "Osmode")
     (if (= (getvar 'Osmode ) 24751)
     (setvar "Osmode" 8367)
     (princ (strcat "\nOSMODE is set to \"" (rtos(getvar "Osmode") 2 0) "\" (ON)"
     );progn true
     (setvar "Osmode" 24751)
     (princ (strcat "\nOSMODE is set to \"" (rtos(getvar "Osmode") 2 0) "\" (OFF)"
     );progn false
     );if
  ((= *ans* "3dosmode")
     (if (= (getvar '3dosmode ) 63)
     (setvar "3dosmode" 62)
     (princ (strcat "\n3D-osmode is set to \"" (rtos(getvar "3dosmode") 2 0) "\"
(ON)"  ))
     );progn true
     (setvar "3dosmode" 63)
(OFF)"  ))
     );progn false
     );if
  ((= *ans* "lineWeight")
     (if (= (getvar 'Lwdisplay ) 0)
     (setvar 'LWDISPLAY 1 )
     (princ (strcat "\nLWDISPLAY is set to \"" (rtos(getvar 'Lwdisplay ) 2 0) "\"
(ON)"  ))
     );progn true
     (setvar 'LWDISPLAY 0 )
(OFF)"  ))
     );progn false
     );if
   )[color=red][b]
  ((= *ans* "onTrack")
     (if (= (getvar 'Autosnap ) 39)
     (setvar 'Autosnap 55 )
     (princ (strcat "\nAUTOSNAP is set to \"" (rtos(getvar 'Autosnap ) 2 0) "\"
(ON)"  ))
     );progn true
     (setvar 'Autosnap 39 )
(OFF)"  ))
     );progn false
     );if
  ((= *ans* "Polar")
     (setvar 'Autosnap 47 )
(ON)"  ))
     );progn true
(OFF)"  ))[/b][/color]
     );progn false
     );if
 );cond
);defun
Edited by Deby Ferdian
there are more paragraph sign!
  • Replies 30
  • Deby Ferdian
    13
  • tombu
    6
  • Grrr
    3
  • David Bethel
    2
Or, this code that what has given by @tombu! It's greate code before when I used it for OSMODE & 3DOSMODE function so far it's works fine and very greate.. but in otherwise when I try with AUTOSNAP for "POLAR" & "ONTRACK". Why??? could you help me?
(defun c:OTR ( / csnap)
 (setq csnap (getvar "Autosnap"))
 (cond
   ((= csnap 24)(setvar "Autosnap" 0))
   ((< csnap 16)(setvar "Autosnap"(+ csnap 16)))
   ((> csnap 16)(setvar "Autosnap"(- csnap 16)))
 (cond
   ((= csnap 24)(princ))
;    ((= csnap 24)(command "'_dsettings"))
   ((< csnap 16)(princ "\n<Object Snap Tracking off>"))
   ((>= csnap 16)(princ "\n<Object Snap Tracking on>"))
(defun c:PLR ( / csnap)
 (cond
   ((< csnap (setvar "Autosnap"(+ csnap ))
   ((> csnap (setvar "Autosnap"(- csnap ))
 (cond
   ((< csnap (princ "\n<Polar off>"))
   ((>= csnap (princ "\n<Polar on>"))
Similar to the OSMODE system variable, the AUTOSNAP system variable is bit-coded, therefore, you will need to use bitwise operations (i.e. logior/logand/boole) to enable or disable the settings.
Following Lee's code example above for tosnap which was much cleaner than mine try:
   (princ (if (zerop (logand 16 (setvar 'autosnap (boole 6 16 (getvar 'autosnap))))) "\n<OsTrack off>" "\n<OsTrack on>"))
   (princ (if (zerop (logand 8 (setvar 'autosnap (boole 6 8 (getvar 'autosnap))))) "\n<Polar off>" "\n<Polar on>"))
Important thing to remember is using this method to toggle turns specific things on/off where setting a value as in your code affects everything controlled by that System Variable. When on my osmode is usually set to 2125, but the osmode toggle examples Lee & I gave you only turned osmode off & on without changing which object snaps were selected.
Of course if you get into customizing the CUI diesel is much better for this stuff. My macro for toggling osnap on/off:
Display Name: $(if,$(and,16384,$(getvar,osmode)),,!.)OSNAP Ctrl+F
Command Name: OSNAP Ctrl+F
Description: Toggles running object snaps on and off: ^F
Macro: ^F
Happy coding!
Thank you very much! for you all you have so much make me felt helped it's very useful and helpfully too many for me.. Thank you again for @tombu, @Grr, @Lee Mac, @marko_ribar, @BKT, @broncos15 and @David Bethel you have got me very well and you were also using the english with a generally that normally people used as a common language and then so to makes me very very easy to get understanding well too. You have understanding about my language too which as I know as you know too if my language knowledge is more than less.. Thank you so much!
Hey, I have a question more.. How about re-assign "F2" for "TEXTSCR" as a toggle show/hide ? I'd always looking for this one in an oftentimes to make it be surely at the CUI option but it just appear CTRL+F2 for "textscr" and while I test it out it won't be Hiding anymore like the persist happening with while when we are going to the press "F2" only in Fullscreen/Maximize/Fullwindow/Cleanscreen mode only.
to make definitely!
Have you looked into (textscr) and (graphscr) ALISP functions, they may be worth of looking for?
Haha.. It's ~AWESOME~ thank you @marko_ribar!
This is be harder similar of the example.. May I ask it in here in the same topic I write? I think this is not too far from this topic this is still same about. How if I want to create a keyboard shortcut of "ESC" ? Not just the only ^C/^C^C/(command) for a cancel function but for all aborting any procceding will proccessing in one act. but this is an excatly persist when we are getting press the "ESC" button. How to we could to make this happen ? Is it can be done ?
ai_deselect - Removes all objects from the selection set
(command) - Cancels commands
But it can't used in transparency mode while another one command is currenty in use or is running, such as; I was in the process of making the line but the middle of a sudden I want to cancel it all of them and this applies to a dialog box or pop-up windows that appears..
add and fix my word of tranparecy!
