Grrr Posted March 22, 2016 Posted March 22, 2016 Hi guys, Yesterday I was experimenting with reading barcode values. But in this example I'll try to keep it simple: ; Example input: 0011 0012 0033... 00XX ; split 0011 to 00 and 11 (the first and 2nd character are separated from 3rd and 4th) ; store 00 value and calculate 11 value (first and 2nd character is stored, and 3rd with 4rth are used for calculations) ; list is constructed with the calculation values ; sum the total of the calculation values in the while loop ; when loop is exited display the grand total of calculation values (defun C:test (/ lst calc-val-list ) (setq lst '( 0 )) (while (setq get-val (getstring t "\nInput value: ")) ; example 0011 (setq code-val (strcat (substr get-val 1 2 ))) ; stored 00 (setq calc-val (strcat (substr get-val 3 2 ))) ; stored 11 string (setq calc-val-num (strcat (rtos (atof calc-val) 2 5) )) ; stored 11 number (princ (strcat "\nCode-val: " code-val " " )) ; display 00 for check (princ (strcat "\nCalc-val: " calc-val-num " " )) ; display 11 number for check (setq calc-val-list (append '(calc-val-num) lst)) ; constructs a list with the stored values (calc-val-num) ; <---- problem here? (princ (strcat "\nCalc-val-list: " calc-val-list " " )) ; this doesn't print, problem?, cannot check );while (setq grand-total (apply '+ (calc-val-list)) ) ; sums the items in the list ; <---- problem here? (princ (strcat "\nGrand-total: " grand-total " " )) ; this doesn't print, problem?, cannot check (princ) );defun As you see I added a little information in the code, but I'll try to explain: 1. It expects 4-character input (numbers) [ex: 1234](string) 2. The first two characters are collected for information. [ex: 12](string) 3. The 3rd and 4th characters are used for calculations. (this should be a number) [ex: 34](number) 4. In the loop a list is constructed, adding the numbers, while values are inputted. [if inputing only 1234, it would be 34+34+34+34...] 5. When exiting the loop it displays the grand-total of the collected items in the list. I have problems in steps 4 and 5 or to be precise, somewhere in these lines of the code: (setq calc-val-list (append '(calc-val-num) lst)) ; constructs a list with the stored values (calc-val-num) ; <---- problem here? (princ (strcat "\nCalc-val-list: " calc-val-list " " )) ; this doesn't print, problem?, cannot check (setq grand-total (apply '+ (calc-val-list)) ) ; sums the items in the list ; <---- problem here? (princ (strcat "\nGrand-total: " grand-total " " )) ; this doesn't print, problem?, cannot check I don't have much experience working with lists, can anyone help? Thanks! Quote
David Bethel Posted March 22, 2016 Posted March 22, 2016 Try changing this : (setq calc-val-list (append '(calc-val-num) lst)) to this: (setq calc-val-list (append 'calc-val-num lst)) Quote
Tharwat Posted March 22, 2016 Posted March 22, 2016 Hi, The variable calc-val-num can not be used like function nor as a symbol, so try the following; (setq calc-val-list (append (list calc-val-num) lst)) Quote
Tharwat Posted March 22, 2016 Posted March 22, 2016 I did not read the complete routine from the first time to encounter that you have other issues , so this must be complete one following your instruction of the user inputs; (setq calc-val-list (append (list calc-val-num) lst)) (princ (strcat "\nCalc-val-list: " (vl-princ-to-string calc-val-list) " ")) ) ;; end of While (setq grand-total (apply '+ (mapcar '(lambda (n) (if (= (type n) 'STR) (atoi n) n)) calc-val-list))) (princ (strcat "\nGrand-total: " (itoa grand-total) " ")) Quote
Grrr Posted March 22, 2016 Author Posted March 22, 2016 Thank you for the help David and Tharwat! It seems that (setq calc-val-list (append (list calc-val-num) lst)) redefines the list, see what it returns for the "calc-val-list" : Input value: 0011 Code-val: 00 Calc-val: 11.00000 Calc-val-list: (11.00000 0) Input value: 0022 Code-val: 00 Calc-val: 22.00000 Calc-val-list: (22.00000 0) Also I was trying to find a way to exit the loop and to display the grand total, so I did: (cond ((= get-val "total") (setq grand-total (apply '+ (mapcar '(lambda (n) (if (= (type n) 'STR) (atoi n) n)) calc-val-list))) (princ (strcat "\nGrand-total: " (itoa grand-total) " ")) ) );cond ) ;; end of While But with the problem above I get (after the 0011 and 0022) inputs: Input value: total Code-val: to Calc-val: 0.00000 Calc-val-list: (0.00000 0) Grand-total: 0 In this case it should display a Grand-total of 33. Quote
Lee Mac Posted March 22, 2016 Posted March 22, 2016 Is this what you are after? (defun c:test ( / lst str ) (setq lst '(0 0)) (while (/= "" (setq str (getstring "\nEnter code <total>: "))) (if (wcmatch str "####") (setq lst (mapcar '+ lst (list (atoi (substr str 3 2)) (atoi (substr str 1 2))))) ) ) (print lst) (princ) ) Quote
Grrr Posted March 22, 2016 Author Posted March 22, 2016 Exactly, Lee! Now I'll study your examples to continue with my experiments. Thanks alot! Quote
Lee Mac Posted March 22, 2016 Posted March 22, 2016 You're welcome - feel free to ask if you have any questions. Quote
