LBUG42 Posted March 22, 2016 Share Posted March 22, 2016 Hi I am using key terrafirma to figure out volume of a mound im new to it so ima haveing some trouble understanding it. There does not seem to be alot about it on internet but the tutorials on here witch are great but i have drawn a mound and would like to find the squaer footage that im going to need to create it, it is drawn in cad in 3d but no luck on figurubg the correct way to do the volume in terrafirma can anyone help? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 Have you tried contacting Key Terra-Firma support? Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 I have been searching on the net but not much info on it ill keep looking. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 This is all I could find. http://www.keycivil.com/support/index.shtml What do you currently have for a drawing? Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 I have just a simple mound drawing useing it to get my head wrapped around the program base is a 0 and goes to 1.5m high. I have followed the tutorials that i could find but no luck. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 Maybe I should have asked that a different way. Do you have a 2D or 3D drawing? Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 Yes sorry i have in 3d Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 Can you attach a copy of the drawing to your next post? If the file size is too large can you make it available via Dropbox and post a link to it here? Maybe someone here would like to see it. Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 ok not a problem 3 Mounds.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 I thought you said it was a 3D drawing. I was expecting something different. Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 it is a simple mound drawing nothing fancy just to see if i can understand how to get the volume of mound. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 The two magenta colored objects are solids and being that they are I can get the volume, in AutoCAD, using the MASSPROP command. Unfortunately the two profiles in the middle wouldn't cooperate with the LOFT command and they produced an unusable result which means I couldn't create a single solid model. Quote Link to comment Share on other sites More sharing options...
LBUG42 Posted March 22, 2016 Author Share Posted March 22, 2016 Thanks that gives me some idea i believe in terrafirma it would be able to get volume but cant seem to figure out if im doing it right i have asked for help on the terrafirma site so hopefully i will get an answer soon. Thanks again you have shown me how to get volume on a simple mound. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2016 Share Posted March 22, 2016 After giving it some thought I'm pretty sure if I continued to do what I did above for the next two mounds then union everything I could get a volume of the entire thing. Just had to get some fresh air to figure that out. My final 3D model as one solid. Sometimes I just over think these things. Quote Link to comment Share on other sites More sharing options...
