ashlie706 Posted January 5, 2009 Posted January 5, 2009 I have a drawing of all the parcels in the county i'm working in, and each parcel is a block, with object data showing the property information. Is there any way to make that object data show up in each block as text? I'm trying to find an alternative to manually typing out the info for HUNDREDS of parcels. Thanks! Quote
rustysilo Posted January 5, 2009 Posted January 5, 2009 If you have created parcels in Civil 3d you can go to your parcel(s) in Toolspace > right-click the parcel > Export Analysis and you will get a text output file that would resemble this: Name: Standard : 1 Point of Beginning : North: 2142769.3756' East: 464760.1385' Segment #1 : Line Course: N8° 29' 46.41"W Length: 198.272' North: 2142965.4717' East: 464730.8449' Segment #2 : Line Course: N73° 07' 37.42"E Length: 171.424' North: 2143015.2275' East: 464894.8889' Segment #3 : Line Course: S29° 28' 00.39"E Length: 208.424' North: 2142833.7654' East: 464997.4163' Segment #4 : Line Course: S74° 49' 02.48"W Length: 245.859' North: 2142769.3756' East: 464760.1385' -------------------------------------------------- Perimeter: 823.979' Area: 41642.29 Sq. Ft. If your parcels data blocks are actually AutoCAD blocks then you can run an attribute extraction (see help file) on it to get the data into a text file. Quote
chulse Posted January 5, 2009 Posted January 5, 2009 Ashlie - I thought you were using LDD 2008, not C3D? Quote
chulse Posted January 5, 2009 Posted January 5, 2009 Rusty - Assuming they are std autocad blocks - can the object data be used to label them (with an attribute I guess)? Quote
