Deby Ferdian Posted March 24, 2016 Posted March 24, 2016 (edited) How if I want to create a keyboard shortcut instead of "ESC" button ? Not just only for ^C/^C^C/(command) of a cancel function but in order for also all aborting any procceding is running in currently proccess in other word in transparency mode while another command is current in use or is running. Such as; I was in the process of making the line but the middle of a sudden I want to cancel it all of them and this applies to a dialog box or pop-up windows that are appears.. And this is an excatly persist that when we are getting press on "ESC" button. How do we could to make this happen ? Is these can be done ? Edited March 26, 2016 by Deby Ferdian Remove word of "But"! Quote
TheCADnoob Posted March 24, 2016 Posted March 24, 2016 In this example she creates a keyboard shortcut for esc using F1 http://lynn.blogs.com/lynn_allens_blog/2005/10/the_best_autoca.html Quote
Deby Ferdian Posted March 24, 2016 Author Posted March 24, 2016 (edited) But it's not applies for PopUp windows or dialogue box are apprears to "close" one of them. I usually press on "ESC" button to use it in these cases.. But I mean How to re-assign this to other ? Edited March 24, 2016 by Deby Ferdian Put on a question! Quote
ReMark Posted March 25, 2016 Posted March 25, 2016 Curoius, why would you want to do that? Not enough real work to keep him busy? Quote
Deby Ferdian Posted March 25, 2016 Author Posted March 25, 2016 to prevent my left hand too often for swing just for doing this only,, Quote
RobDraw Posted March 25, 2016 Posted March 25, 2016 That must be one big keyboard or you have a really small left hand. On a side note, if you are escaping out of dialog boxes that often, you might want to look at why you are opening them in the first place. Quote
RobDraw Posted March 25, 2016 Posted March 25, 2016 Unfamiliarity with the program? A great reason to not customize. Quote
Deby Ferdian Posted March 25, 2016 Author Posted March 25, 2016 or could somebody can got me on another my topic, See this link about create a section crash into the geomatrical. please! http://www.cadtutor.net/forum/showthread.php?96188-Create-a-LISP-as-a-function-for-Section-Plan-gt-View-to-the-section-gt-UCS-to-the-current Quote
