Zeusovsky Posted January 5, 2009 Posted January 5, 2009 How can i get the red circles in the drawing. I want to drawing the red circles in other drawing but with his properties, the circles are inside of BlockReferece I tried some codes but i nothing get.The circles not appear in the Model Space or in a SelectionSets, When i use SelectionSet i put SSetColl in Watches but appear empty. If some body have a code for help me with this issue i appreciate to much your help I want only the red circles for redrawing in other drawing i need the object because i will need change the radius of some there. Example: Dim Block as AcadBlock For each Block in ThisDrawing.Blocks '...some code for get circles Next or Dim SSetColl as AcadSelectionSets SSetColl = ThisDrawing.SelectionSets For Each Block in SSetColl '...some code for get circles Next or Dim SSetColl as AcadSelectionSet SSetColl = ThisDrawing.PickfirstSelectionSet For Each Block in SSetColl '...some code for get circle Next Quote
Zeusovsky Posted January 5, 2009 Author Posted January 5, 2009 How can i get the red circles in the drawing. I want to drawing the red circles in other drawing but with his properties, the circles are inside of BlockReferece I tried some codes but i nothing get.The circles not appear in the Model Space or in a SelectionSets, When i use SelectionSet i put SSetColl in Watches but appear empty. If some body have a code for help me with this issue i appreciate to much your help I want only the red circles for redrawing in other drawing i need the object because i will need change the radius of some there. Example: Dim Block as AcadBlock For each Block in ThisDrawing.Blocks '...some code for get circles Next or Dim SSetColl as AcadSelectionSets SSetColl = ThisDrawing.SelectionSets For Each Block in SSetColl '...some code for get circles Next or Dim SSetColl as AcadSelectionSet SSetColl = ThisDrawing.PickfirstSelectionSet For Each Block in SSetColl '...some code for get circle Next TEST.dwg Quote
