abra-CAD-abra Posted March 29, 2016 Posted March 29, 2016 Guys, I have recently started using the VLIDE editor and how I wish I started using it earlier! When formatting code in the editor using 'Format Code in Editor', the formatting never looks neat. I am using the default settings in: Tools > Environment Options > Visual Lisp Format Options Is there anything I am missing or should know for better formatting? Cheers, Quote
abra-CAD-abra Posted March 30, 2016 Author Posted March 30, 2016 (edited) Lee, Thank you for your response. That would explain why the formatting of your code is always flawless. I have been playing with the formatting settings in VLIDE for some time but I cannot achieve the desired presentation. I find that if the code is formatted well, it is easier to read and understand. In future, I think that I will use VLIDE for debugging and Notepad++ for formatting. Cheers Lee, Edited March 30, 2016 by abra-CAD-abra Quote
cwake Posted March 30, 2016 Posted March 30, 2016 I find the formatting in the VLIDE is a good start when the code that I have received from elsewhere is very different to how I prefer it. But like you, I find it has limitations. However, the tool I am constantly using in the VLIDE for tidying up my own code is "Indent to current level". I usually apply it as "Select code (or Ctrl A), Ctrl E => Indent to current level". But you can also access it under the "Edit => Extra Commands" menu. Quote
abra-CAD-abra Posted March 30, 2016 Author Posted March 30, 2016 Thanks Clint, I will investigate the 'indent to Current Level' options. Cheers, Quote
