askrius Posted January 5, 2009 Posted January 5, 2009 Is there any way to retrieve the XCLIP bounds associated with a specific XREF (BlockRef, in this case)? Quote
VVA Posted January 5, 2009 Posted January 5, 2009 (defun bg:block-GetXclip ( vla-obj / result ) ;;Если блок подрезан, возвращает SPATIAL, иначе nil ;;If the block is clipped, returns SPATIAL filter, differently return nil ;; test ;; (bg:block-GetXclip (vlax-ename->vla-object(car(entsel "\nSelect clipped xref")))) (vl-catch-all-apply '(lambda ( ) (if (and (eq (vla-get-ObjectName vla-obj) "AcDbBlockReference") (eq :vlax-true (vla-get-HasExtensionDictionary vla-obj) ) ) (setq result (entget (vlax-vla-object->ename (vla-item (vla-item (vla-getExtensiondictionary vla-obj) "ACAD_FILTER" ) "SPATIAL" ) ) ) ) ) ) ) result ) Pay attention to group 10 Quote
