superlong Posted April 2, 2016 Posted April 2, 2016 (edited) for example i select 10 polyline to a list then i want to sort this list by coordinate y of firt point of each polyline ( every polyline have many point) Edited April 2, 2016 by superlong Quote
cwake Posted April 2, 2016 Posted April 2, 2016 Assuming LWPolylines, and that their direction of definition is suitable... see http://forums.augi.com/showthread.php?137837-Sort-Selectionset-by-X-coord&p=1164026&viewfull=1#post1164026 That post (i.e. the line of code in point 2) describes how you would sort a list by x value. To sort by y, take that code, and just replace BOTH occasions of "cadr" with "caddr". To sort by z, you would do the same but replacing "cadr" with "last", or "cadddr". Quote
superlong Posted April 2, 2016 Author Posted April 2, 2016 this is my code to get area for many polyline select but i want to sort their polyline before get area (defun c:yeah ( / dt dt1 dt2 rec1 rec2 pt ss) (if (not sc3) (setq sc3 2)) (setq sc1 (getreal (strcat "\nChi\U+1EC1u cao Text <"))) (if (not sc1) (setq sc1 sc3) (setq sc3 sc1)) (setq sc9 (cdr (assoc 1 (entget (car (entsel "\nChon Text Ly Trinh <end of> : ")))))) (setq dt (ssget '((0 . "LWPOLYLINE")))) (setq sdt (sslength dt) K SDT i 0) (while (setq dt1 (ssname dt i) dt2 (ssname dt (1+ i)) i (1+ i) K (- K 1) rec1 (acet-geom-vertex-list dt1) rec2 (acet-geom-vertex-list dt2) pt (nth 0 rec1) ) (if (and (< (car (nth 0 rec1)) (car (nth 2 rec1))) (< (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 (reverse rec2) (list pt)))) (if (and (> (car (nth 0 rec1)) (car (nth 2 rec1))) (> (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 (reverse rec2) (list pt)))) (if (and (< (car (nth 0 rec1)) (car (nth 2 rec1))) (> (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 rec2 (list pt)))) (if (and (> (car (nth 0 rec1)) (car (nth 2 rec1))) (< (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 rec2 (list pt)))) (acet-pline-make (list ss)) (command "area" "o" (entlast)) (setq dientich (getvar "area")) (setq s (strcat (rtos dientich 2 2))) (command "INSERT" "DIENTICHL" (nth 1 rec2) SC1 SC1 0 sc9 K S) ) (princ "\nThanks for Using - Ho\U+00E0ng Long Auto Lisp Phone:0933118500 Mail:longnguyen4563@gmail.com") (PRINC)) Quote
cwake Posted April 2, 2016 Posted April 2, 2016 This would take your original selection set of LWPolylines, sort them by the y value of the FIRST vertex of each polyline in DESCENDING order, and then recreate your selection set IN THAT ORDER. You might want to be localising more variables than you currently are. There doesn't seem to be any point in having both SC1 and SC3 as global variables. And SC9? SDT? And so on... (defun c:yeah ( / dt dt1 dt2 rec1 rec2 pt ss) (setq sc3 (setq sc1 (cond ((getreal "\nChi\U+1EC1u cao Text <")) (sc3) (2.0) ) ) ) (if (and (setq sc9 (entsel "\nChon Text Ly Trinh <end of> : ")) (setq sc9 (cdr (assoc 1 (entget (car sc9))))) (setq dt (ssget '((0 . "LWPOLYLINE")))) (> (setq sdt (sslength dt)) 1) ) (progn ( (lambda ( / i e ss ) (repeat (setq i sdt) (setq e (ssname dt (setq i (1- i))) ss (cons (cons (caddr (assoc 10 (entget e)) ) e ) ss ) ) ) (setq dt (ssadd)) (foreach x (vl-sort ss (function (lambda ( a b ) (> (car a) (car b)) ) ) ) (ssadd (cdr x) dt) ) ) ) ;; I'm not touching anything below here!! (setq K SDT i 0) (while (setq dt1 (ssname dt i) dt2 (ssname dt (1+ i)) i (1+ i) K (- K 1) rec1 (acet-geom-vertex-list dt1) rec2 (acet-geom-vertex-list dt2) pt (nth 0 rec1) ) (if (and (< (car (nth 0 rec1)) (car (nth 2 rec1))) (< (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 (reverse rec2) (list pt)))) (if (and (> (car (nth 0 rec1)) (car (nth 2 rec1))) (> (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 (reverse rec2) (list pt)))) (if (and (< (car (nth 0 rec1)) (car (nth 2 rec1))) (> (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 rec2 (list pt)))) (if (and (> (car (nth 0 rec1)) (car (nth 2 rec1))) (< (car (nth 0 rec2)) (car (nth 2 rec2)))) (setq ss (append rec1 rec2 (list pt)))) (acet-pline-make (list ss)) (command "area" "o" (entlast)) (setq dientich (getvar "area")) (setq s (strcat (rtos dientich 2 2))) (command "INSERT" "DIENTICHL" (nth 1 rec2) SC1 SC1 0 sc9 K S) ) (princ "\nThanks for Using - Ho\U+00E0ng Long Auto Lisp Phone:0933118500 Mail:longnguyen4563@gmail.com") ) ) (princ) ) Quote
