A lisp to change blocks in a layer to a layer with a prefix of that layer
I currently do this a clumsy way using a macro and 2 filters, copying to clipboard, erasing what I don't need, renaming layers with RENAME command, then pasting back from the clipboard all the geometry that needs to keep the original layer name!
But all I actually need is that any block in any layer in a drawing be moved into a layer that has a prefix of "SYM_"layer.
Can this be done in AutoLISP? Any hints at where I should start looking?
If you are using AutoCAD LT as noted by your profile, an AutoLISP solution will not be possible.
Hi Lee Mac, thanks for your response.
Yes, my profile still says LT. I am currently in a full version trial, and trying to solve 3 things to justify the upgrade.
I have confirmed 2, and now this is the last one.
Can I change my question? I have learned more and am now comfortable with "Command", so I just need a method to loop through all layers in a drawing and add a suffix to each.
BlackBox's code from this thread: http://www.cadtutor.net/forum/showthread.php?51619-renaming-layers-with-a-prefix
Seems to be what I need, but I am not able to debug it (even after 2 hours of attempts). It looks like the exact logic I am after. Ill bet there is simply some syntax that I cannot recognise as a small error yet.
(defun SUFFIX  (arg / oldLayerName)   [color=seagreen];; Example: (SUFFIX "-TEST")[/color]   (vl-load-com)   (cond     (*activeDoc*)     ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))   (vlax-for x  (vla-get-layers *activeDoc*)     (if (and       (not (vl-position        (setq oldLayerName (strcase (vla-get-name x)))        '("0" "DEFPOINTS")))       (not (vl-string-search "|" oldLayerName)))    (vla-put-name x (strcat oldLayerName arg))))   (princ)) ;_end defun
 (vl-load-com)
 (cond
   (*activeDoc*)
   (if (and
     (not (vl-position
Edited by YZ
I see where you're struggling to paste copied code... Use notepad as helper tool (copy+paste code from cadtutor to notepad firstly)... Then post code by (copy+paste from notepad into code tags [noparse]
 Your code here ...
[/noparse])...
Yeah I tried Notepad already.
This time I pasted from the VLIDE, and that seemed to work much better.
Thanks.
Try this and see if it needs debugging...
(defun c:blkslayprefix ( / PREFIX ss i e )
 (defun PREFIX ( arg oldLayerName )
   (if (and
         (not (vl-position oldLayerName '("0" "DEFPOINTS")))
     (strcat arg oldLayerName)
     oldLayerName
 (prompt "\nSelect blocks to rename their layer names to names with specified prefix...")
 (setq ss (ssget "_:L" '((0 . "INSERT"))))
 (while (not ss)
   (prompt "\nEmpty sel.set... Please select blocks to rename their layer names to names with specified prefix again...")
 (initget 1)
 (setq pref (getstring t "\nSpecify prefix : "))
   (setq e (ssname ss (setq i (1- i))))
   (entupd (cdr (assoc -1 (entmod (subst (cons 8 (PREFIX pref (cdr (assoc 8  (entget e))))) (cdr (assoc 8 (entget e))) (entget e))))))
Edited by marko_ribar
That looks promising!
This is the error I get when I run it:
Here's a very simple form of such a program:
(defun c:laysuf ( / pat suf )
   (setq suf "-test"
         pat (strcase (strcat "0,defpoints,*|*,*" suf))
   (vlax-for lay (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
       (or (wcmatch (strcase (vla-get-name lay)) pat)
           (vla-put-name lay (strcat (vla-get-name lay) suf))
(vl-load-com) (princ)
Note that this does not account for cases in which appending the suffix will result in a duplicate layer.
  • 1 month later...
Thanks Lee, long time coming but I got back to this only today.
This works like a dream. Except I wrote suffix where I should have written prefix.
I tried wrangling your routine into a prefix equivalent, but I think I still need some coaching on what this line is doing:
Here's what I came up with:
(defun c:laypref ( / pat suf )
   (setq pre "SYM_"
         pat (strcase (strcat "0,defpoints,*|*,*" pre))
           (vla-put-name lay (strcat pre (vla-get-name lay)))
I'm glad the code is working for you.
You will also need to change:
to:
pat (strcase (strcat "0,defpoints,*|*," pre "*"))
And change this:
( / pat suf )
to:
( / pat pre )
Gets and Puts are programming terms I am getting old used in Basic 30 years ago.
Get go and retrieve something you would use Assoc if using dxf codes
Put change something you would use ENTMOD if using dxf codes
Thanks BIGAL!
Lee Mac, yep, that's all it was.
For the benefit of readers, to add a nominated prefix to layers:
(defun c:laypref ( / pat pre )
   (setq pre "SYM_"
I am trying, but still I read sample lisps and I get lost as to what is happening. To stop asking silly questions, is there a basics course or resource I can read? Everything I read so far is so different from the next that I feel like I haven't learnt anything that helps me interpret the next lisp!
But, I have dreamed of prefixing layers for YEARS!
I bought 4 Visual lisp books for Kindle/pc from Amazon and they were ony a few dollars each I think they were like $8 dollars each they have lisp books as well.
Being here in AUS I have a convert "Civilcad" changes all the layer, names, Linetype and colour like you adds EX_ to survey code/layer name, does lots more happy to share. What is your survey software ? Have you gone to CIV3D ?
Hey Bigal, using Magnet (formerly CivilCAD) and AutoCAD. Not Civil3D at this stage.
I'd gladly look at your transfer lisp if you were willing. Was it that obvious that it was a land surveying lisp I was making?! Haha.
What the lisp does is a number of things converting a Civilcad export to dwg.
1 removes the cross point block
2 changes line types to only Autocad & supported custom.lin is ok, this removes link to SHX created for each dwg.
3 converts all line work to 2d maintains 3dfaces as 3d for contouring.
4 keeps a Autocad Point of each surveyed point as a 3d value.
5 converts layers re linetype and colour based on a external txt file that has all survey codes, adds EX as its Field survey. This is part of our construction dwg requirement.
Can you post a export dwg from Magnet for testing.
  • 1 month later...
07-154SEW.dwg
This file is the dwg exported directly from magnet. Is this the format you were expecting?
Sorry for the delay, I issed it somehow. But thanks for the offer.
Here is the same after running the conversion, all the point blocks are gone and replaced with an Autocad POINT type Ptype still 3d, your layer linetypes have been modified to match true AutoCAD line types so eliminating the annoying message about missing shx. See Solid and Dash now gone. You would need to tell me what 12,14 & 84 linetypes are then they to can be unlinked from the shx also. The renaming of the layers could be removed its part of our standards to identify existing v's design.
Please note we had a dot linetype and opening a dwg was horrendous time wait changed the line type in civilcad to stop the problem, looked at 84 not sure of the pattern.
07-154SEW-2.dwg
This is all very promising. Thanks again for taking the time.
