Find and replace text...but only layout's name?
Hi,
It's possible to find this?
I need to rename a lot layout's name from a dwg (for sample):
Floor 00.1 ----> Floor 01.1
Floor 00.2 ----> Floor 01.2
Floor 00.3 ----> Floor 01.3
thanks!!
Hi,
Are you talking about specific layout names as in your example or ALL layouts to deduct the zero which is on the left side hand ?
Show an example.
As you can see here, i need to replace:
APP A1.xx to APP A2.xx (for 2nd floor)
APP A1.xx to APP A3.xx (for 3th floor) ...
There must be a criteria to follow for renaming layouts, so what is the principle in your case?
Weel i find this on the net...it's look like working like a find replace only for layouts!
What do you think about this?
(defun c:FRlayout (/ #Find #Replace)
 (vl-load-com)
 (and
   (setq #Find (getstring T "\nFind what: "))
   (setq #Replace (getstring T "\nReplace with: "))
   (not (vl-position "" (list #Find #Replace)))
   (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
     (vl-catch-all-apply 'vla-put-name (list x (vl-string-subst #Replace #Find (vla-get-name x))))
   ) ;_ vlax-for
 ) ;_ and
) ;_ defun
Edited by SLW210
Changed Quote Tags to Code Tags!
You need also something like lee-macs parse numbers when you get the layout name use parse numbers to return the 1.02 and check if its with in the range of layouts you want to change start ="App 1.03" end ="App 1.11" gives 1.031.11 etc then only change the correct layouts. The code you have is nearly there.
