broncos15 Posted April 7, 2016 Posted April 7, 2016 I was curious is there anyway to determine the number of lines of text (or the text box height) in a multileader object? I have done a dump of all the information and I don't see anything that references this. The reason I ask is because I am trying to add onto Lee's code found here: http://www.cadtutor.net/forum/showthread.php?76430-Multi-Leader-Shrinkwrap. My thought is to have an iteration that starts at 1.01 and increase the tolerance in 0.01 increments until the text box height is the same as it was initially (I have messed with the tolerance numerous times and I can't get a value that works all the time, but still shrinks the text box). Quote
Tharwat Posted April 7, 2016 Posted April 7, 2016 Hi, You can get the number of lines by the quantity of the combination strings \\P in the Mtext string if found. Quote
broncos15 Posted April 7, 2016 Author Posted April 7, 2016 Hi, You can get the number of lines by the quantity of the combination strings \\P in the Mtext string if found. Thanks Tharwat for the help! So I looked into your suggestion, which I can get from vla-get-textstring, or dxf group code 304, but the problem is that the \\P information is only available if the user hits enter for a new line of text, not if the text is put on a second line by dragging the text box, at least as far as I can tell. Quote
BIGAL Posted April 8, 2016 Posted April 8, 2016 Dump of 3 line mtext, does your look like this ? TextString = "abcdefg\\Phijklm\\Popqrst" Quote
Lee Mac Posted April 8, 2016 Posted April 8, 2016 Divide the height of the MLeader text box by the text height + line spacing - there is a similar example for MText somewhere on the web. Quote
broncos15 Posted April 8, 2016 Author Posted April 8, 2016 Dump of 3 line mtext, does your look like this ? TextString = "abcdefg\\Phijklm\\Popqrst" When I have a multileader that has 2 lines of text that look like this: Cadtutor is helpful. It prints like this TextString = "CADTUTOR IS HELPFUL" Divide the height of the MLeader text box by the text height + line spacing - there is a similar example for MText somewhere on the web. . Thanks Lee! I'll play around with it for a while to see if I can figure it out. Quote
broncos15 Posted April 8, 2016 Author Posted April 8, 2016 So I have been messing around with this and I still am confused. I have a text box that has a width of 29.9248, which after looking through the dxf codes I see is group code 43. The text box height is 5.3333333, but I can't find any information on this. I have tried to do 29.9248/5.33333 which gives 5.61, however, there isn't any group code that has 5.3333 or 5.61. I also know the text height is 2.0 (code 40), so I tried to do 5.3333-2.0=3.3333 to find the height, but there isn't a group code with that value either. Am I missing something/ going about this incorrectly? Quote
marko_ribar Posted April 8, 2016 Posted April 8, 2016 Maybe this by Lee... ;; by Lee Mac ;; http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Determining-the-number-of-lines-in-a-... (defun mattrib-number-of-lines (ent / box enx) (setq enx (entget ent) box (textbox (list '(1 . "A") (assoc 7 enx) (assoc 40 enx))) ) (1+ (fix (/ (cdr (assoc 43 enx)) (* 1.66 (- (cadadr box) (cadar box)))))) ) ;; mtxtattrib-number-of-lines HTH, M.R. Quote
broncos15 Posted April 11, 2016 Author Posted April 11, 2016 Maybe this by Lee... ;; by Lee Mac ;; http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Determining-the-number-of-lines-in-a-... (defun mattrib-number-of-lines (ent / box enx) (setq enx (entget ent) box (textbox (list '(1 . "A") (assoc 7 enx) (assoc 40 enx))) ) (1+ (fix (/ (cdr (assoc 43 enx)) (* 1.66 (- (cadadr box) (cadar box)))))) ) ;; mtxtattrib-number-of-lines HTH, M.R. Thanks marko (and Lee as well for his code)! So I tested that on an mleader object and it doesn't work because of the different dxf group codes, but it works perfectly on the mtext object. I have hard time converting it over to use for mleader because I can't figure out all the eqivalent dxf group codes. I know that 1 for mtext is equivalent to 304 for mleader (the first 304 code given), 40 to 40 (the second one given) but I can't find any equivalent for 7 (style), or 43 ( I am not sure exactly what this gives). Quote
Lee Mac Posted April 11, 2016 Posted April 11, 2016 I can't find any equivalent for 7 (style), or 43 ( I am not sure exactly what this gives). Group 43 gives the height of the MText text box - as far as I am aware, there is no equivalent DXF group for an MLeader. However, I have already provided a function to calculate this height (and also demonstrate how to obtain the MLeader Text Style), linked above. Quote
broncos15 Posted April 11, 2016 Author Posted April 11, 2016 Group 43 gives the height of the MText text box - as far as I am aware, there is no equivalent DXF group for an MLeader. However, I have already provided a function to calculate this height (and also demonstrate how to obtain the MLeader Text Style), linked above.Lee, I'm sorry I should have done a check with that other function before posting. I think I have got it figured out now. Quote
