sanchez Posted April 7, 2016 Posted April 7, 2016 Will someone please show me how to measure an arc,(part of a circle) and the perimeter of a circle in Solidworks? Thank you, Diego Quote
sanchez Posted April 8, 2016 Author Posted April 8, 2016 I suppose I should have said that I am looking for the length of the arc and the length (circumference) of a circle. Sorry Diego Quote
JD Mather Posted April 12, 2016 Posted April 12, 2016 I assume you are in an active sketch. Select the Dimension command. Click first endpoint of the arc. Click the second endpoint of the arc. Select the arc. Now you should see the arc length dimension. Quote
sanchez Posted April 12, 2016 Author Posted April 12, 2016 I assume you are in an active sketch.Select the Dimension command. Click first endpoint of the arc. Click the second endpoint of the arc. Select the arc. Now you should see the arc length dimension. Thank you sir! Quote
shift1313 Posted April 20, 2016 Posted April 20, 2016 in addition to what JD said which is how you dimension the arc length, if you are in the part(not the sketch) and are trying to measure a circular edge use the measure tool. Depending on which version of SW you are using it might be in different places. On 2015 and older you should see it just under the TOOLS drop down menu or on Evaluate tab. In 2016 they tucked it away but it will still be on evaluate. When you select a circular edge it will give you the Length and its diameter(or radius if its not a full circle). Quote
