Does anyone know the command to take a paper space object and send it through the viewport into model space (without copy and paste)?
I think it may be one of the default commands on the standard right-click shortcut menu in 06 version.
  • 2 years later...
how to bring model objects in viewports
can we change the color of model space objects in view port without affecting in model space?
You are in a paper space layout and have created at least one viewport right?
Yes. Activate the viewport. Click on the object. Open your Layer Properties Manager. Go to the column with the heading VP Color and change it. The same object in all other viewports it is depicted in will remain in the original color assigned.
  • 4 months later...
pick what you nedd and copy to clipboard then go back to modelspace and paste.
