pmxcad Posted April 13, 2016 Posted April 13, 2016 Hello, Is it possible to change the layer from a wipeout in a block with a lisp? I know ho it can be done bij script using ssx. But it's not working on wipeouts in a block. I like to change the wipeout from layer "0" to layer "Wipeout". Thanks PmxCAD Quote
marko_ribar Posted April 13, 2016 Posted April 13, 2016 Try this... (defun c:wipechlayer ( / *error* *adoc* cnt blocks ss i flag ) (vl-load-com) (defun *error* ( msg ) (vla-endundomark *adoc*) (vla-regen *adoc* :vlax-false) (if msg (prompt msg) ) (princ) ) (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark *adoc*) (setq cnt 0) (setq blocks (vla-get-blocks *adoc*)) (vlax-for x blocks (if (eq (vla-get-isxref x) :vlax-false) (vlax-for item x (if (eq (vla-get-objectname item) "AcDbWipeout") (if (eq (vla-get-lock (vla-item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) (vla-get-layer item))) :vlax-false) (progn (if (wcmatch (strcase (vla-get-name x)) "*MODEL*,*PAPER*") (progn (entupd (cdr (assoc -1 (entmod (subst (cons 8 "Wipeout") (assoc 8 (entget (vlax-vla-object->ename item))) (entget (vlax-vla-object->ename item))))))) (setq cnt (1+ cnt)) ) (progn (command "_.BEDIT" (vla-get-name x)) (setq ss (ssget "_A" '((0 . "WIPEOUT")))) (repeat (setq i (sslength ss)) (entupd (cdr (assoc -1 (entmod (subst (cons 8 "Wipeout") (assoc 8 (entget (ssname ss (setq i (1- i))))) (entget (ssname ss i))))))) (setq cnt (1+ cnt)) ) (command "_.BCLOSE" "") ) ) ) (setq flag T) ) ) ) ) ) (prompt (strcat "\nNumber of wipeouts changed layer: " (itoa cnt))) (if flag (prompt "\nSome wipeouts could not be changed with new layer. Check for locked layers..." ) ) (*error* nil) ) (defun c:wchl nil (c:wipechlayer)) (prompt "\nInvoke with : \"wchl\"") (princ) Regards... Quote
Tharwat Posted April 13, 2016 Posted April 13, 2016 Try this program in pure Vanilla: (defun c:wo2laywo (/ sel obj nxt ent blk lst) ;;====================================;; ;; Tharwat - 13.Apr.2016 ;; ;; Move WIPEOUT objects in blocks to ;; ;; layer name WIPEOUT is existed. ;; ;;====================================;; (if (and (tblsearch "LAYER" "WIPEOUT") (setq sel (ssget "_:L" '((0 . "INSERT")))) ) (progn (while (setq obj (ssname sel 0)) (if (and (setq nxt (tblobjname "BLOCK" (setq blk (cdr (assoc 2 (entget obj)))))) (not (member blk lst)) ) (progn (setq lst (cons blk lst)) (while (setq nxt (entnext nxt)) (if (eq "WIPEOUT" (cdr (assoc 0 (setq ent (entget nxt))))) (entmod (subst '(8 . "WIPEOUT") (assoc 8 ent) ent)) ) ) ) ) (ssdel obj sel) ) (command "_.regen") ) (princ "\nEither Layer name <WIPEOUT> is not found or nothing selected !") ) (princ) ) Quote
pmxcad Posted April 15, 2016 Author Posted April 15, 2016 Thanks Marco & Tharwat, both are super. I prefer the one made by Marco. It runs without selecting objects. PmxCAD Quote
