hemsley Posted April 23, 2016 Posted April 23, 2016 Hi All, Can someone help with converting two attribute values to decimal from hexadecimal and then performing a simple mathematical operation on the two values and returning the result in the third attribute. The attached block has three attributes (AC, ADDRESS and DEV). The values for AC and ADDRESS are written in hexadecimal. The DEV value will be in decimal format. So, convert the AC value to decimal; convert the ADDRESS value to decimal; then add the two decimal values and return as the value in the DEV attribute. Any help would be greatly appreciated. Hex2Dec.dwg Quote
Lee Mac Posted April 23, 2016 Posted April 23, 2016 Try the following: (defun c:hex2dec ( / a b c e i l s x ) (if (setq s (ssget "_:L" '((0 . "INSERT") (2 . "RS") (66 . 1)))) (repeat (setq i (sslength s)) (setq e (entnext (ssname s (setq i (1- i)))) x (entget e) ) (while (= "ATTRIB" (cdr (assoc 0 x))) (setq l (cons (list (strcase (cdr (assoc 2 x))) (cdr (assoc 1 x)) x) l) e (entnext e) x (entget e) ) ) (if (and (setq a (assoc "AC" l)) (setq b (assoc "ADDRESS" l)) (setq c (assoc "DEV" l)) (entmod (subst (cons 1 (itoa (+ (LM:base->dec (cadr a) 16) (LM:base->dec (cadr b) 16)))) (assoc 1 (caddr c)) (caddr c) ) ) ) (entupd (cdr (assoc -1 (caddr c)))) ) ) ) (princ) ) ;; Base to Decimal - Lee Mac ;; Converts an number in an arbitrary base to decimal. ;; n - [str] string representing number to convert ;; b - [int] base of input string ;; Returns: [int] Decimal representation of supplied number (defun LM:base->dec ( n b / l ) (if (= 1 (setq l (strlen n))) (- (ascii n) (if (< (ascii n) 65) 48 55)) (+ (* b (LM:base->dec (substr n 1 (1- l)) b)) (LM:base->dec (substr n l) b)) ) ) (princ) Base to Decimal from my set of Base Conversion Functions. Quote
hemsley Posted April 23, 2016 Author Posted April 23, 2016 Thanks Lee, But how and where do I load the function? Quote
Lee Mac Posted April 23, 2016 Posted April 23, 2016 You're welcome. Please follow the instructions from my tutorial here: How to Run an AutoLISP Program. Quote
hemsley Posted April 23, 2016 Author Posted April 23, 2016 Thanks Lee, Great stuff. But can I ask if we can expand on the simple addition. Rather than summing the values of the attributes AC and ADDRESS can we have the following. DEV = 695164 +(((AC*632)+ADDRESS)*6). The values 695164, 632 and 6 are static values and will not change. I've tried various constructions in the line of code starting (cons 1 (itoa (+ (LM:base.........) but can't get it right. Quote
Lee Mac Posted April 23, 2016 Posted April 23, 2016 can we have the following.DEV = 695164 +(((AC*632)+ADDRESS)*6). The values 695164, 632 and 6 are static values and will not change. Sure, change: (cons 1 (itoa (+ (LM:base->dec (cadr a) 16) (LM:base->dec (cadr b) 16)))) to: (cons 1 (itoa (+ 695164 (* 6 (+ (* (LM:base->dec (cadr a) 16) 632) (LM:base->dec (cadr b) 16)))))) Quote
hemsley Posted April 23, 2016 Author Posted April 23, 2016 Thanks Lee again. No reply to further query. Figured it out myself. Quote
MarcK Posted October 23, 2020 Posted October 23, 2020 Hi is there any way to do this in a table? I had an excel formula "=695164+((HEX2DEC($B2)*632)+HEX2DEC($C2))*6+1" but can't put this in to a cad table. I know I can link it in an excel table but I really need it to be fool proof for anyone editing the drawing. Quote
BIGAL Posted October 24, 2020 Posted October 24, 2020 Like others here, this is a example make a table lisp. There is no code re the convert hex2dec as that is answered earlier in the post. ; make table example ; By Alan H info@alanh.com.au ; 2018 (defun c:ahmaketable (/ colwidth numcolumns numrows objtable rowheight sp vgad vgao vgms) (vl-load-com) (setq sp (vlax-3d-point (getpoint "pick a point for table"))) (Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))) ; (setq numrows 5) (setq numcolumns 5) (setq rowheight 2.5) (setq colwidth 60) (setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth)) (vla-settext objtable 0 0 "DRAWING REGISTER"); TABLE TITLE (vla-settext objtable 1 0 "DRAWING NUMBER") (vla-settext objtable 1 1 "DRAWING TITLE") (vla-settext objtable 1 2 "C") (vla-settext objtable 1 3 "D") (vla-settext objtable 1 4 "E") (vla-settext objtable 2 0 "1") (vla-settext objtable 3 0 "2") (vla-settext objtable 4 0 "3") (command "_zoom" "e") (princ) ) You can then add rows to a table and fill in cells values using. (setq obj2 (vlax-ename->vla-object (entlast)) (setq rownum (vla-get-rows obj2)) (vla-InsertRows obj2 rownum (vla-GetRowHeight obj2 (- rownum 1)) 1) (vla-settext obj2 rownum colnum txt) Quote
