PaulS00 Posted April 25, 2016 Posted April 25, 2016 Hello! So whenever I am making a line, multileader, etc, and I click over a hatch pattern, it snaps to the hatch origin waaay out in the middle of nowhere (0,0,0 maybe). I searched around and found the OSNAPHATCH variable, but it is already turned OFF. It's extremely annoying. Thoughts? Thanks, -TD Quote
Dadgad Posted April 26, 2016 Posted April 26, 2016 Might you be using Dynamic UCS? Is your OSOPTIONS system variable set to 0? If so, try changing it to 1. Quote
RobDraw Posted April 26, 2016 Posted April 26, 2016 OSNAPHATCH is for snapping to objects within a hatch. I think you are referring to the insert snap of the hatch. Turn that off in running snap settings. Quote
