So, I'm sure anyone that knows Inventor will be able to tell, but I am new to it. Many years of CAD but about a week in Inventor.
I've been trying all morning to add holes to a part. My idea was to make a sketch, extrude it and then add a hole and pattern as needed. The linear option was no good to place the holes b/c my sides are not square with each other, so I when back and edited the sketch to place a pair of construction lines crossing at my intended hole center. I place a Center Point at the spot, but when I went to add a Hole feature later, (trying From Sketch and By Point), Inventor didn't pick up the Center Point. I finally googled enough to find that I could click on Sketch1 (which Extrusion1 is based on and through which Hole1 will go), click Share Sketch and now I can add a Hole feature using the From Sketch option. Questions are as follows
1) Why can I not use the endpoint or intersection of the construction lines to place a Hole using the On Point option?
2) Do I even want to do this? Is it better to make a Sketch1 and a subsequent Extrusion1 and THEN create a new sketch on the face of Extrusion1 and base my Hole feature on that? I guess I'm asking should my reference marks be contained in that most base sketch or is there a compelling reason to separate a sketch that will only define a feature from the sketch that defines the base object?
THANKS!!!
1. On Point only works with Work Point features.
2. Sketch points is the easiest and most common way of placing holes. Generally the sketch is a separate sketch. You can toggle the endpoints of lines (or rectangles) from points to sketch points in upper right corner of screen.
