sandiegophil Posted April 28, 2016 Share Posted April 28, 2016 Hello, I have found the 'best practices' under help / learning resources but want to get a pdf of this. Back in the old days we received books, now we get html. Does anyone have a resource for these? Thanks, phil Quote Link to comment Share on other sites More sharing options...
MillerMG Posted April 28, 2016 Share Posted April 28, 2016 I'm not sure I quite understand what it is you're trying to achieve and what documents are you speaking of? I looked up learning resources in the help and saw a bunch of stuff and not sure what one in particular you are speaking of. Thanks, Miller Quote Link to comment Share on other sites More sharing options...
benhubel Posted April 28, 2016 Share Posted April 28, 2016 You can try using a Print to PDF utility. The one I'm familiar with is Win2PDF, but there are others out there as well. Just print the help files and select the driver as your printer. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted April 28, 2016 Author Share Posted April 28, 2016 Miller, From the help pull-down, under 'learning resources' 12th item from the bottom there is a topic called 'Best Practices Guide'. I am trying to find a pdf file that is all inclusive of that topic. Autodesk used to provide actual, physical books for these items but no longer does. Thanks, phil Quote Link to comment Share on other sites More sharing options...
MillerMG Posted April 28, 2016 Share Posted April 28, 2016 You cleared that up perfectly Phil. Let me take a look and I'll get back to you sir. Miller Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted April 28, 2016 Author Share Posted April 28, 2016 benhubel, I have tried online utilities, acrobat x pro and acrobat pro dc. All of them will only produce the first sheet, the introduction. I have tried to do the entire site, 1 level deep, 100 level(s) deep all with no success. Any additional suggestions would be appreciated. Thanks, phil Quote Link to comment Share on other sites More sharing options...
benhubel Posted April 28, 2016 Share Posted April 28, 2016 I don't know how much has changed between the 2011 and the 2016 versions, but here's the older of the two. http://images.autodesk.com/adsk/files/civil_best_practices0.pdf Quote Link to comment Share on other sites More sharing options...
MillerMG Posted April 28, 2016 Share Posted April 28, 2016 well there you go. Nice Ben! Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted April 28, 2016 Author Share Posted April 28, 2016 benhubel, thank you for the file and the effort. it is appreciated. Quote Link to comment Share on other sites More sharing options...
benhubel Posted April 29, 2016 Share Posted April 29, 2016 Glad to help. It seems that there are yet a few things on this forum that I can be of assistance with Being that I'm relatively new to the CAD side of things, I have to jump on the few that I actually know something about. Quote Link to comment Share on other sites More sharing options...
Organic Posted April 29, 2016 Share Posted April 29, 2016 The move away from pdfs to html help files annoys me also as the search capabilities usually aren't as good. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted April 29, 2016 Author Share Posted April 29, 2016 all help is always appreciated! Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted April 29, 2016 Author Share Posted April 29, 2016 Organic, I couldn't agree more. At least provide the option to replicate sections of the html to pdf. Quote Link to comment Share on other sites More sharing options...
