keiths Posted May 2, 2016 Posted May 2, 2016 Hi Is there a way I can set defaults in the below menu... Quote
ReMark Posted May 3, 2016 Posted May 3, 2016 keiths: Which "below menu" are you referring to? If you want a command to default to a particular option consider using either a macro assigned to a button or a lisp routine. Quote
keiths Posted May 3, 2016 Author Posted May 3, 2016 Hi ReMark, I have attached an image of the toolbar, am afraid I don't have much of a clue with macros or lisp routines... Quote
rkent Posted May 3, 2016 Posted May 3, 2016 You will have to create a tool button somewhere, the ribbon or on a tool palette. The macro would be ^C^C_arraypath;\;\;;;I;6;M;D;; This will be for 6 items, modify for the number you want as a default. Quote
ReMark Posted May 3, 2016 Posted May 3, 2016 I'm still waiting to see the toolbar. The image you posted is of the Array command's contextual ribbon tab. What default(s) did you want to set to the toolbar you speak of? Quote
BIGAL Posted May 4, 2016 Posted May 4, 2016 Here is the lisp equivalent you would add to your acaddoc.lsp and just type AP. (defun c:ap6 ( / obj obj2 num) (setq obj (car (entsel "pick object"))) (setq obj2 (car (entsel "pick path"))) (command "_arraypath" obj "" obj2 "I" 6 "" "M" "D" "") ) Quote
Hudy Posted January 19, 2024 Posted January 19, 2024 This is very interesting topic, I understand that M is the parameter for distance and it reads the length of curve and what is D for? It prompts me to put Dimension type, what are the options and effect for this macro? Currently I removed this parameter from my function as I don't find any use for it. Quote
BIGAL Posted January 20, 2024 Posted January 20, 2024 (edited) 7 years ago wow, just run Arraypath manually or Google help Arraypath Autocad. Edited January 20, 2024 by BIGAL Quote
