I pulled my layers panel off the tool bar so it would be easier to use. Is there a way to dock it to the side of the work space like some other panels or does it only dock to the ribbon?
Are you talking about a panel you pulled from the Ribbon?
Type this -toolbars layers show, toolbar will apear not ribbon
Yeah the layers panel in the ribbon I pulled it down into my work space so I could switch layers without having to click the tabs above the ribbon to get back to it every time. I tried to dock to the side of the work space but it wont dock.
Another alternative is to Copy/Paste the Layers Panel into each Ribbon in the CUI so that it's always there. You have a few options like this with the Ribbon.
Would that be a constant variable for every time I opened autocad?
Yes, it would be a permanent change.
Thank you very much for posting this! Great video
