DuanJinHui Posted May 4, 2016 Posted May 4, 2016 Use ""ssget" ,I want filter non-uniformly scaled block. (setq ss (ssget (list '(0 . "INSERT")))) Any good idea? Thanks. Quote
Tharwat Posted May 4, 2016 Posted May 4, 2016 Hi, You may need to change the value of 1.0 to your desired one. (setq ss (ssget '((-4 . "<NOT") (-4 . "<AND") (0 . "INSERT") (41 . 1.0) (42 . 1.0) (43 . 1.0) (-4 . "AND>") (-4 . "NOT>") ) ) ) Quote
DuanJinHui Posted May 4, 2016 Author Posted May 4, 2016 Hi, You may need to change the value of 1.0 to your desired one. (setq ss (ssget '((-4 . "<NOT") (-4 . "<AND") (0 . "INSERT") (41 . 1.0) (42 . 1.0) (43 . 1.0) (-4 . "AND>") (-4 . "NOT>") ) ) ) Thanks Tharwat. But this is not I need. I need choose uniformly scaled blocks . eg. (41 . 1.0)(42 . 1.0)(43 . 1.0) (41 . 2.0)(42 . 2.0)(43 . 2.0) (41 . 3.0)(42 . 3.0)(43 .3.0).... etc. Quote
DuanJinHui Posted May 4, 2016 Author Posted May 4, 2016 I know use "entsel" function can do this: (setq blkref (car (entsel "\n>>>Choose a block:"))) (if (not(= (cdr(assoc 41 (entget blkref))) (cdr(assoc 42 (entget blkref))) (cdr(assoc 43 (entget blkref))))) (progn (alert "\nNOT support non-uniformly scaled block.") t ) (progn Quote
Tharwat Posted May 4, 2016 Posted May 4, 2016 I am really not sure that you can filter many blocks with different scale values of X,Y and Z but you can have only one as I've demonstrated in the first reply. Otherwise you can make a selection set of blocks then cycle through each block object and add objects to a list when their scales X,Y,Z are matched. Quote
DuanJinHui Posted May 4, 2016 Author Posted May 4, 2016 I am really not sure that you can filter many blocks with different scale values of X,Y and Z but you can have only one as I've demonstrated in the first reply. Otherwise you can make a selection set of blocks then cycle through each block object and add objects to a list when their scales X,Y,Z are matched. Maybe need write a sub-function. Quote
Tharwat Posted May 4, 2016 Posted May 4, 2016 Maybe need write a sub-function. Try it and let me know if you need any help. Quote
DuanJinHui Posted May 4, 2016 Author Posted May 4, 2016 Try it and let me know if you need any help. Maybe need 1 day or more . I will try . Quote
Tharwat Posted May 4, 2016 Posted May 4, 2016 Maybe need 1 day or more . I will try . Nooo, it is simple. If you don't try and give at least 75% of codes correct, I won't reply to any of your threads anymore. Quote
DuanJinHui Posted May 4, 2016 Author Posted May 4, 2016 (edited) Nooo, it is simple. If you don't try and give at least 75% of codes correct, I won't reply to any of your threads anymore. This ? Any suggestions ? Thanks. (defun newss(/ ss i ename ) (while (if (null(setq ss (ssget (list '(0 . "INSERT"))))) (progn (alert "\nNothing select. Try again.") t ) (progn (repeat (setq i (sslength ss)) (setq ename (ssname ss (setq i (1- i)))) (if (not (= (cdr(assoc 41 (entget ename)))(cdr(assoc 42 (entget ename)))(cdr(assoc 43 (entget ename)))) ) (setq ename(ssdel ename ss)) ) ) nil ) ) ) ename ) So,if need use this new selection set. ; test (setq en (newss)) (command "_.move" en "") Edited May 4, 2016 by DuanJinHui Add testing code. Quote
Tharwat Posted May 4, 2016 Posted May 4, 2016 So far so good You don't need the while function and the return of the function must be the variable ss and not the entity name and a few little mods. Keep on coding and no matter how many mistakes you would have. Take a look. (defun newss (/ ss i ename) (if (setq ss (ssget (list '(0 . "INSERT")))) (repeat (setq i (sslength ss)) (setq ename (ssname ss (setq i (1- i)))) (if (not (= (cdr (assoc 41 (entget ename))) (cdr (assoc 42 (entget ename))) (cdr (assoc 43 (entget ename)))) ) (ssdel ename ss) ) ) (alert "\nNothing select. Try again.") ) ss ) Quote
David Bethel Posted May 4, 2016 Posted May 4, 2016 (edited) Maybe : [b][color=BLACK]([/color][/b]defun c:noteq [b][color=FUCHSIA]([/color][/b]/ ss i en ed[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq neq [b][color=NAVY]([/color][/b]ssadd[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]= [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 41 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 42 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 43 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]ssadd en neq[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]alert [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"UnEqual Scaked Blocks Found = "[/color] [b][color=MAROON]([/color][/b]rtos [b][color=GREEN]([/color][/b]sslength neq[b][color=GREEN])[/color][/b] 2 0[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] global neq PICKSET -David Edited May 5, 2016 by David Bethel Quote
BIGAL Posted May 5, 2016 Posted May 5, 2016 Using VL easy to just compare X & Y & Z etc dont need to remember the assoc code ; XEffectiveScaleFactor = 1.0 ; XScaleFactor = 1.0 ; YEffectiveScaleFactor = 2.0 ; YScaleFactor = 2.0 ; ZEffectiveScaleFactor = 1.0 ; ZScaleFactor = 1.0 Quote
DuanJinHui Posted May 5, 2016 Author Posted May 5, 2016 Thanks Tharwat and David . Hi David. My drawing have non-uniformly scaled block. I use your code for testing. But alert "UnEqual Scaled Blocks Found=0" Quote
David Bethel Posted May 5, 2016 Posted May 5, 2016 Hi David. My drawing have non-uniformly scaled block. I use your code for testing. But alert "UnEqual Scaled Blocks Found=0" My bad, I forgot /= has a quirk in that (/=1 2 2) returns nil. I fixed the code in post #12 -David Quote
Lee Mac Posted May 5, 2016 Posted May 5, 2016 Do you want to select non-uniformly scaled blocks but ignore mirrored blocks (i.e. for which the x-scale factor is negative)? Since the block scale is stored as a double, I would recommend using the equal function with some tolerance when performing the comparison, i.e.: (defun c:selnublocks ( / i s x ) (if (setq s (ssget "_X" (list '(0 . "INSERT") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))) (repeat (setq i (sslength s)) (setq x (entget (ssname s (setq i (1- i))))) (if (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) (ssdel (cdr (assoc -1 x)) s) ) ) ) (sssetfirst nil s) (princ) ) Quote
DuanJinHui Posted May 6, 2016 Author Posted May 6, 2016 Do you want to select non-uniformly scaled blocks but ignore mirrored blocks (i.e. for which the x-scale factor is negative)? Since the block scale is stored as a double, I would recommend using the equal function with some tolerance when performing the comparison, i.e.: (defun c:selnublocks ( / i s x ) (if (setq s (ssget "_X" (list '(0 . "INSERT") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))) (repeat (setq i (sslength s)) (setq x (entget (ssname s (setq i (1- i))))) (if (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) (ssdel (cdr (assoc -1 x)) s) ) ) ) (sssetfirst nil s) (princ) ) I ignore mirrored blocks. Many Thanks Lee. If I want select uniformly scaled blocks, Just replace "equal" to "/=" , Right ? Mention mirrored blocks ,I reminded a question. http://www.cadtutor.net/forum/showthread.php?96562-Lee-s-MirrorBlock.lsp-have-a-bug Quote
Lee Mac Posted May 6, 2016 Posted May 6, 2016 I ignore mirrored blocks. Many Thanks Lee. If I want select uniformly scaled blocks, Just replace "equal" to "/=" , Right ? I would suggest enclosing the (and) expression with a (not) to reverse the condition. Quote
DuanJinHui Posted May 6, 2016 Author Posted May 6, 2016 I would suggest enclosing the (and) expression with a (not) to reverse the condition. Lee,Thank you again. Like this? (if (not (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) ) (ssdel (cdr (assoc -1 x)) s) ) Quote
