iztok13 Posted May 4, 2016 Posted May 4, 2016 Hello, I have problem to get polyline where two surfaces are crossing. I have an existing ground surface and another surface lets say a waterline surface. Now i need to get polyline where these surface are intersect. Is there any chance to get these? Sorry form my bad english. Thx.. Quote
BIGAL Posted May 5, 2016 Posted May 5, 2016 Waterline is easy as its a known contour value you may need to set a style to get it to show. Let me think how did I do it last time. Intersection of 2 surfaces say sloping would be at again cut/fill is zero. Good question. Dont do very often. Quote
iztok13 Posted May 5, 2016 Author Posted May 5, 2016 ok i did it. Create a new volume-surface that shows Surf1-Surf2, set the style to show contours (just one contour at elevation = 0) and extract that contour as this is the intersection-line between Surf1 and Surf2. thx bigal for replaying Quote
JerryG Posted May 16, 2016 Posted May 16, 2016 Another way to do it is create an assembly that has the option to simply target your existing surface so that you could see exactly were they meet. Quote
