marko_ribar Posted May 5, 2016 Posted May 5, 2016 Hi, I don't know what else is bugus from (acet-xxx) functions... I've experienced bug with (acet-geom-ss-extents-accurate) in A2016 and this report confirm that that's the case and with A2017 : http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/convert-2d-polylines-to-3d-polylines-with-elevation/m-p/6307610/highlight/true#M341073 I don't know ab A2015, but on A2014 I haven't had such problems... So do you know something ab this issue and with other (ACET-XXX) functions? For now as I looked others (acet-xxx) functions it seems to work as expected, but if you know something or how to fix this help us and inform me for such fix... I've also read that for A2015,16,17,... you need to change (command) function inside error handler to (command-s) and change (command) to (command-s) if its called inside (mapcar '(lambda ( x ) ...) loop to avoid VVC error... Any new info and on this matter is helpful also... Maybe something else than (command-s); I don't know... Thanks for reading, M.R. Quote
