tmelancon
Edit LISP to rename blocks.. Thanks in advance.
tmelancon
First off KUDOS to Tharwat for this brilliant LISP. Can someone edit so its doesnt prompt user for Suffix.. I want the suffix to be -NEW all the time. Also for the block selection I would just like for the lisp to select all everytime. Will be running this on a folder of specific individual blocks. I did in fact try, I just havent succeeded yet thanks.
(defun c:RenBlks (/ Blocks *error* cm r ss int sn sfx kw bks nam)
 (vl-load-com)
;;;         Tharwat 31. Oct. 2012             ;;;
;;;   Rename selected or All Blocks as User's inputs    ;;;
 (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
 (setq Blocks (vla-get-blocks acdoc))
 (setq cm (getvar 'cmdecho))
 (defun *error* (x)
   (if cm
     (setvar 'cmdecho cm)
   (vla-EndUndoMark acdoc)
   (princ "\n")
   (princ "\n *Cancel*:")
 (if (and (not (eq (setq sfx (getstring t "\n Specify Suffix :")) ""))
          (setq r (snvalid sfx))
          (progn (initget "Selected All")
                 (setq kw (cond ((getkword "\n Rename [selected . All] Blocks < Selected > :"))
                                ("Selected")
   (if (eq kw "All")
     (progn (vla-StartUndoMark acdoc)
            (vlax-for x Blocks (vl-catch-all-apply 'vla-put-name (list x (strcat (vla-get-name x) sfx))))
     (if (setq ss (ssget "_:L" '((0 . "INSERT"))))
              (setvar 'cmdecho 0)
              (repeat (setq int (sslength ss))
                (setq sn (ssname ss (setq int (1- int))))
                (setq nam (cdr (assoc 2 (entget sn))))
                (if (not (member nam bks))
                  (progn (vl-cmdf "_.-rename" "B" nam (setq nam (strcat nam sfx))) (setq bks (cons nam bks)))
   (cond ((not sfx) (princ "\n Cancelled by user "))
         ((not r) (princ "\n Not Valid Block name "))
         (t (princ "\n Cancelled by user "))
 (princ "\n Written by Tharwat Al Shoufi")
Share this post
Link to post
Tharwat
Hi,
Thank you for the nice words and for using one of my a bit old programs.
Is this what you are after?
(defun c:renblks  (/ acdoc)
 (vla-endundomark acdoc)
 (vla-startundomark acdoc)
 (vlax-for x  (vla-get-blocks acdoc)
   (if (and (= (vla-get-islayout x) :vlax-false)
            (= (vla-get-Isxref x) :vlax-false)
            (not (wcmatch (vla-get-name x) "*-NEW"))
     (vl-catch-all-apply
       'vla-put-name
       (list x (strcat (vla-get-name x) "-NEW"))))
 )(vl-load-com)
Share this post
Link to post
tmelancon
Wow not only are you great, you're fast! Works like I was anticipating! Side note.. would it be a hassle to write a IF statement in there to overlook the block if the block SUFFIX is already NEW... Cheers 4 everything
Share this post
Link to post
Tharwat
Thank you.
Yes sure, it is already included in the program - so no re-renaming to blocks that already have a suffix of *-NEW.
NOTE: At the first post of my first reply I didn't include in the program to exclude Xref & layouts so if you copied the codes before that just recopy the new codes for a better performance.
Share this post
Link to post
tmelancon
BEAST MODE. Very much obliged.
Share this post
Link to post
Tharwat
You're welcome.
Share this post
Link to post
nod684
Hi,
     (vl-catch-all-apply
       'vla-put-name
 )(vl-load-com)
nice one. this will be useful.
thanks
Share this post
Link to post
