PaulS00
Change Layer and Create New Layer If Needed LISP
PaulS00
Hello!
So I've been Googling around the internet and am trying to find a LISP that, upon selecting an object, would place that object on a demo layer and if that layer is not present, would create it.
For example,
If I have a point on the V-NODE-CONC layer, upon selecting it, the LISP would switch it to the "V-NODE-CONC-DEMO" layer. If that layer hasn't yet been created, it would copy the "V-NODE-CONC" LAYER, set it to color 240, and add the "-DEMO" suffix.
Thoughts?
Thanks!
Share this post
Link to post
Lee Mac
Try the following:
(defun c:demo ( / e i l n s x )
   (if (setq s (ssget "_:L" '((8 . "~*-DEMO"))))
       (repeat (setq i (sslength s))
           (setq x (entget (ssname s (setq i (1- i))))
                 l (assoc 8 x)
                 n (strcat (cdr l) "-DEMO")
           (if (not (tblsearch "layer" n))
                   (setq e (entget (tblobjname "layer" (cdr l))))
                   (entmake (subst (cons 2 n) (assoc 2 e) (subst '(62 . 240) (assoc 62 e) e)))
           (entmod (subst (cons 8 n) l x))
Share this post
Link to post
PaulS00
Try the following:
                 l (assoc 8 x)
Fantastic!
One important thing I forgot to mention, is that I need it to work on Civil 3D points and survey figures when we are demoing a topo drawing.
Sorry about that!
Share this post
Link to post
Lee Mac
Fantastic!
Sorry about that!
I don't use Civil 3D (or any of the Verticals), but maybe the ActiveX route will enable compatibility with such objects:
           (setq x (vlax-ename->vla-object (ssname s (setq i (1- i))))
                 l (vla-get-layer x)
                 n (strcat l "-DEMO")
           (if (or (tblsearch "layer" n)
                   (and (setq e (entget (tblobjname "layer" l)))
               (vla-put-layer x n)
(vl-load-com) (princ)
Share this post
Link to post
PaulS00
                 l (vla-get-layer x)
               (vla-put-layer x n)
It worked for some of the survey figures, but for points and the other survey figures (don't know how there is a difference) I get this..
; error: Automation Error. Key not found
Thanks for the effort Lee Mac! You're the man!
Share this post
Link to post
Lee Mac
Interesting - try the following instead:
(defun c:demo ( / i l n s x )
                 l (vla-get-layer x)
           (if (checkmakelayer l n) (vla-put-layer x n))
(defun checkmakelayer ( a b )
   (cond
       (   (tblsearch "layer" b))
       (   (setq a (tblobjname "layer" a))
           (setq a (entget a))
           (entmake
               (subst (cons 2 b) (assoc 2 a)
                   (subst '(62 . 240) (assoc 62 a)
                       (vl-remove-if '(lambda ( x ) (or (= 'ename (type (cdr x))) (= 102 (car x)))) a)
I'm guessing the layer could have an extension dictionary present which may be causing problems when duplicating it.
Share this post
Link to post
PaulS00
                 l (vla-get-layer x)
   (cond
           (setq a (entget a))
           (entmake
HO-LY SHET!! YES!!
I'm going to talk to my boss about kicking down a donation for you.
Thanks Lee Mac!!
Share this post
Link to post
Dadgad
HO-LY SHET!! YES!!
Thanks Lee Mac!!
:shock::notworthy::thumbsup::celebrate::beer:
Share this post
Link to post
Lee Mac
HO-LY SHET!! YES!!
Thanks Lee Mac!!
Many thanks Paul! - I'm pleased that the code is working well.
Share this post
Link to post
capnsjules
Attempting to swap out the suffix of -demo for a prefix sd-; also attempting to maintain the original layers color. However the lisp does nothing.
I have cobbled together the following code:
   (if (setq s (ssget "_:L" '((8 . "SD*~"))))
                 l (vla-get-layer x)
                 n (strcat l "SD-")
   (cond
           (setq a (entget a))
           (entmake
                   (subst '(62 . 256) (assoc 62 a)
Share this post
Link to post
Lee Mac
Try the following:
   (if (setq s (ssget "_:L" '((8 . "~SD-*"))))
                 l (vla-get-layer x)
                 n (strcat "SD-" l)
   (cond
           (setq a (entget a))
           (entmake
Share this post
Link to post
troggarf
Many thanks Dr. Lee
Share this post
Link to post
d1saster
                 l (vla-get-layer x)
   (cond
           (setq a (entget a))
           (entmake
Hi guys. First post here. I would like to express my admiration to all contributors here. Plenty of usable info posted.
This code works great and I am trying to add some to it. Is it possible to assign the color of the new layer based on the color of the original layer:
If the original layer color is 1 the new layer to be 201; if it is 2 to become 202, etc. for colors from 1 to 8. I assume a loop or condition check has to be added to (subst '(62 . 240) (assoc 62 a) but programming is not my strength.
Thanks
Share this post
Link to post
Lee Mac
Welcome to CADTutor :thumbsup:
Try the following quick modification -
                 l (vla-get-layer x)
(defun checkmakelayer ( a b / c )
   (cond
           (setq a (entget a)
                 c (abs (cdr (assoc 62 a)))
           (entmake
                   (subst
                       (cons  62 (if (< c 9) (+ c 200) c))
                       (assoc 62 a)
Share this post
Link to post
d1saster
It works flawlessly. Thank you Lee!
Share this post
Link to post
Lee Mac
You're most welcome!
Share this post
Link to post
phidrho
Hi,
I'm having similar problem, I have prepared drawing template with many layers defined by specification, something like this:
first_layer_name
first_layer_name-description1
first_layer_name-description2
first_layer_name-description3
first_layer_name-description4
second_layer_name
second_layer_name-description1
second_layer_name-description2
second_layer_name-description3
second_layer_name-description4
third_layer_name
third_layer_name-description1
third_layer_name-description2
third_layer_name-description3
third_layer_name-description4
Description is always same for all layers (currently there are 4 possible variants, like above).
So my job is to go through drawing, select elements in base layer (without description) and change layer to one with description, depending on situation, sometimes it should go to layer with description1, sometimes in others.
I would like to automate this with keyboard shortcuts, something like this: select an element in "first_layer_name" and press "SHIFT+1" and it would go to layer "first_layer_name-description1", with "SHIFT+2" it should go to "first_layer_name-description2" and so on. Lisp should work in other way too (if I make mistake), select an element in "first_layer_name-description2" press "SHIFT+1" and it would go to "first_layer_name-description1".
I figured out how to create keyboard shortcuts - I created macro which runs lisp command and created Shortcut Key for macro and it works, so only problem left is pretty complicated lisp routine.
Share this post
Link to post
