samifox Posted May 9, 2016 Posted May 9, 2016 hi using acad 2010, lookimh for a way to detach all unreferenced xref at once thx Quote
Dana W Posted May 9, 2016 Posted May 9, 2016 XREF manager lets you multi-select.Yes, just like in any list, select the first one, hold down the shift key, select the last one, then right click in the highlighted area, and select Detach. Before you do that, sort by the Status column so the detached ones will all be together. Quote
