I have a quick question if there is any other way to store a variable to the registry besides setenv or vl-registry-write. The reason that I ask is that setenv requires a string, which means that I have to make use of the rtos function (with maximum precision of 8 ) to convert the variable value (in this case viewtwist) to a string. The problem is that on very large projects this precision can cause some issues.
Thanks marko, that's a cool routine! The problem I have though is that it still makes use of a conversion from a number to a string. I know that I could make use of vl-bb-set, but this only works in one session as well.
which means that I have to make use of the rtos function (with maximum precision of [noparse]8)[/noparse]
The precision of rtos is only limited by the maximum precision of the double-precision floating-point format (~15 decimal places):
_$ (rtos pi 2 15)
"3.141592653589793"
FWIW, contrary to what is stated by the developer documentation, the vl-registry-write function can also write integer values to the registry (as a REG_DWORD).
Hi broncos
rtos can return up to 16 decimals, if the number is less than 1.0
(if
 (setq p (getpoint "\nSpecify first point: "))
 (setenv "my_var" (rtos (car p) 2 16))
For larger numbers, it can return maximum 16 digits, so you will loose some of the precision.
You can compensate using this:
(if
 (setenv "my_var"
   (strcat "(+ "
           (vl-princ-to-string (fix (car p)))
           ".0 "
           (rtos (- (car p) (fix (car p))) 2 16)
Then you can retrive the stored value like this:
(setq my_var (eval (read (getenv "my_var"))))
Hi broncos
(if
(if
 (setenv "my_var"
   (strcat "(+ "
           ".0 "
I'm trying to think of way to make use of a while loop that would continue to go until it had reached the actual end of the value. For example 2.1234567890123456789 would be stored as + 2.0 0.1234567890123456 0.0000000000000000789. Do you think that this is possible?
Also, Lee, thank you so much for letting me know that the vl-registry-write function can also write integer values to the registry. I am curious, how did you find this out because I am now wondering what other functions might not be properly documented.
So I have been messing around with this, and I think the solution would involve a repeat function that makes use of function similar to strlen but for numbers (does a function like this exist?). My thought is a code like:
(Repeat (numberstrlen (- myvalue (fix (myvalue))))[/color]
[color=black];;;rest of code that keeps adding values to the end, but I am unsure of how to do this[/color]
[color=black])[/color]
It will not help you. All the numbers are truncated to most 16 decimals:
_$ (equal 2.1234567890123456789 2.1234567890123456 1e-17)
T
_$
Maybe you need to reconsider your code. It might be possible to avoid this rounding error with a different approach.
I can't remember whether I had perhaps read it on one of the CAD forums, or whether I encountered it by mistake...
T
_$
So I ended up figuring out that AutoCAD stores 48 decimal places for pi (I think this has to do with a 64 bit vs 32 bit processor), so I decided to do a repeat loop that iterates over a number and adding each digit individually to the string. Thanks again for the help. And Lee, thanks again for pointing it out, sometimes it seems like the idiosyncrasies of LISP can only be encountered through experience.
