RickyD302 Posted January 6, 2009 Posted January 6, 2009 I need to know how to select the dimension pts so I can stretch a dimension. I can add the dimension object to my selection set with no problem but then the whole dimension moves when I really just want to stretch the dimension. When I try to just get the control pts then I get a fatal error indicating that "The object invoked has disconnected from its clients" Ideas, hints work arounds? Quote
RickyD302 Posted January 7, 2009 Author Posted January 7, 2009 fcode(0) = -4: ftype(0) = " fcode(1) = 0: ftype(1) = "INSERT" fcode(2) = 100: ftype(2) = "Dimension" fcode(3) = -4: ftype(3) = "or>" On Error Resume Next ThisDrawing.SelectionSets.Item("HandleSelection").Delete On Error GoTo 0 Set objss = ThisDrawing.SelectionSets.Add("HandleSelection") objss.Select acSelectionSetCrossing, pt1, pt2, fcode, ftype For Each objSelection In objss objSelection.Move vOldPT, HandleLocPT objSelection.Update Next I then tried to add the control points fcode(3) = 14: ftype(3) = vOldPT I was getting the fatal error because I was only provide one dimension of a 3 point array fcode(3) = 14: ftype(3) = vOldPT(0) ---FATAL I'm thinking that I have to indicated that I'm looking for dimension but don't give me all of it by using the Quote
