I just installed 2017 Mechanical, but I'm using a copy of the Vanilla Profile. I migrated all of my stuff from 2016 and all seems ok except my custom Ribbon Tabs are missing. I can manually load my CUIx file, all is good, then I save the custom workspace and export my custom profile.
Restart AutoCad, my custom profile is in the startup icon, my workspace loads ok, but my custom CUIx file does not load. The path for my custom CUIx file is correct in the options files area
Any help with this? anybody else have this issue?
Thanks
Tom
Have you got this working? Did you try adding those Ribbon tabs to a Workspace? That CUI & it's dll file must be in both Support & Trusted paths.
