BBBLLL Posted May 18, 2016 Posted May 18, 2016 Hi everybody! I need some help because I don't understand how I can put together a cam and its follower so that I can make them move. Attached to this post there are my parts. My goal is to make in contact the tip of the follower and the lateral surface of the cam, and then the follower should go up and down while the cam rotates. Thanks for your help camma.ipt cedente.ipt Quote
gazza_au Posted May 19, 2016 Posted May 19, 2016 Sorry only have 2015 version so cant open these ipt's, have a look here. Quote
BBBLLL Posted May 24, 2016 Author Posted May 24, 2016 gazza_au: the video is useful, but I have another kind of follower with a tip instead of a rotating element. Do you know how I can add a joint in this case? Quote
gazza_au Posted May 24, 2016 Posted May 24, 2016 Can you save the parts in a previous version so i can open them ? I only have Inventor 2015. Quote
BBBLLL Posted May 25, 2016 Author Posted May 25, 2016 If I can, I will save them in a previous version. Meanwhile, here it is the draft. LP CAD - Esercitazione 07 - Traccia.pdf Quote
ajamit007 Posted May 30, 2016 Posted May 30, 2016 In Dynamic Simulation Goto Insert Joint and Select "Sliding : Point Curve", Rest is mentioned on video posted by gazza_au Before doing the Simulation you'll need to constraint both the part in an Assembly Environment. Quote
