I am using AutoCAD 2015 and I'm unable to explode hatch patterns. I tested the file with other computers in the office and it worked fine so it has to be a setting on my machine. Under the hatch and gradient window the associative option is grayed out. I have tried the "HPASSOC" command and it was set to . Any suggestions?
Thanks!
Any chance you can share the drawing or enough of it that we can see the problem ourselves?
Remark,
I can't get the file size small enough to load on the site, sorry.
Just need a drawing with some hatching in it. It doesn't have to be the size of Texas; Rhode Island would do well enough.
Sorry, It's only a tiny 3" x 3" area of hatch now and it's still over 1 mg. I've tried purging but I still can't get the file to upload.
Thanks anyway!
  • 3 weeks later...
Thanks!
Is it a block that you imported from an external source? If so i do not think that you can explode it.
Exploding hatches is usually not a good idea. It has a way of making things difficult at a later time.
  • 2 weeks later...
RobDraw is correct and many others will give you the same advise. But if you are importing a block from an external source here is how you can do it. Not hard just time consuming. The following is using a mouse & keyboard.
pull up the drawing that you want to import the block to. use VIEW - ZOOM - ALL pick a clear spot to import the block you want (usually to the right of your drawing.)
Import the block to a clear area --- use VIEW - ZOOM - WINDOW draw a window around the block this gives you only the block to work on.
click on the "make a block icon" or type block on the command line.
this will give you the block making window the will pop up on your screen.
(left my notes at home so will have to wing it from here)
at the top will be a window asking for the block name name it so that you will know what it is
on the left side of the window will be a icon (with a arrow pointing to it) asking you to choose article
click on this icon
the window will be disappear
type w on the command line
press enter on the keyboard
draw a window around your block that you have imported --- LEAVE 1 LINE THAT YOU CAN GET TO EASY
use erase and click on the line that you did not draw over
draw the line you left to compete your block
right click the mouse button or press enter on the keyboard
your make a block screen will reappear on the left side of the screen will be another icon with an arrow pointing to it labeled pick insertion point click on it
window will disappear again pick a spot on the block that you have just made
click the right mouse button or press enter on the keyboard
now choose erase and erase the block that you just made
use VIEW - ZOOM - PREVIOUS do this until you are back to where it tells you no previous view save
go to where you want to insert the block you just made
chose insert and choose the block that you just made tell it ok
insert the block explode it do what you want then.
I'd redraw the block from scratch before I'd go through all that hassle.
Plus, the OP asked about a hatch. No mention of a block at all.
Why? What is stopping you?
Here is what the command process should be like. How is your's different?
Command: EXPLODE
Select objects: 1 found [i]( <-- select the hatch )[/i]
Select objects:
Command: [i](Okay, it's exploded)[/i]
Use the LIST command and then pick the Hatch, paste the result here.
I have seen a similar issue where the issue was the hatch was a clipped block. are these hatches freshly created or did you copy the hatch from another file?
is there a little blue arrow grip that shows up when you select this hatch?
Dog gone it i did it again. Have to start paying more attention to what i am eading.
