brooksdesign Posted May 31, 2016 Posted May 31, 2016 Hi everyone, dont know how i did it by my dimensions now appear with an explanation mark beside them streaming a disassociation. Not sure what variable to track on this one, Thanks Quote
ReMark Posted May 31, 2016 Posted May 31, 2016 You have two options per your AutoCAD Help file. Solution: To toggle the annotation monitor off: At the command line, enter ANNOMONITOR and set this variable to -1. To keep the annotation monitor on, and reassociate the dissociated dimension: Select the alert next to the dimension. Choose Reassociate. Select the point that the dimension should reassociate with. Quote
brooksdesign Posted May 31, 2016 Author Posted May 31, 2016 Thankyou, not sure how i changed the annomonitor variable ?? Quote
RobDraw Posted May 31, 2016 Posted May 31, 2016 Funny, I just helped someone out with that. It is a button at the bottom of the AutoCAD window that is a big "+". You could have hit it by accident. Quote
